LANTIC L003 DISSECTED
I bought this device in Taiwan and hope to mod it out by adding a second antenna and a heatsink, so stay tuned If you look closely at the innards photo, you'll see it has a PCB almost exactly the same as the dual antenna, TV Cloud Stick. Moreover, it gets a bit hot with the 1080p kernel by gin running.
How to root this (or likely any 3188/3066) device: http://www.freaktab.com/showthread.p...ssfully-rooted!
How to install CWM Recovery on this (or likely any 3188/3066) device: http://www.freaktab.com/showthread.p...8-3066-devices
LANTIC L003 REVIEW
Pros:
- It can read and write to NTFS partitioned USB flash drives (though USB3 and exFAT drives aren't readable)
- WiFi range is excellent
- Bluetooth has mid-to-excellent range & I'm able to use a mouse, keyboard and speaker simultaneously without disconnections, lag or miscellaneous problems
- It plays 1080p videos stably and doesn't get too hot doing it
- Excellent overall stability; haven't experienced a crash since I got it
- Generic enough to find working ROMs and kernels for it
Cons:
- Not rooted (but easy to root)
- Has a dumbed-down version of 4.2 (but not too dumb; can be modified easily enough)
- Not a lot of pre-installed apps
- No heatsink whatsoever
- WiFi antenna is cheap and might be broken easily (though the device is easy to open & it'd probably easy to mod the antenna & perhaps a second antenna)
More to follow. I hope I can help people who buy this device in Taiwan
