Step One:
Download The Root Package Here
Step Two:
Connect Your Tablet To Your PC
Step Three:
Copy The Root Package (Whole Thing) Onto The External Sd Card
Step Four:
Safely Remove The Tablet From Your PC
Step Five:
On Your Tablet, Turn It Off Then Hold Either Power Button And Down On The Volume Rocker Or Power Button And Both Sides Of The Volume Rocker Until It Goes Into Recovery Mode
Step Six:
Go Down To 'Apply Update From Sdcard' And Press The Power Button
Step Seven:
Go Down To 'Kyser_Root-signed.zip' And Press The Power
Step Eight:
Once It Installs, Press Power To Reboot The System
Step Nine:
Install Your Preferred Super User App (I Recommend SuperSU By Chainfire)
You Should Now Have FULL Superuser Access, Consider Yourself Rooted.
.gif)
If You Have Any Problems Or Questions Just Ask Because I Am Happy To Help You Fellow Nextbook Users
