Ramos i9 - Hands-On review
Originally posted by m1cke View PostI have problems with the Playstore. Several apps are not compatible with this tablet. Tried market helper and some build.prop changes, helped with some apps but others I can't install.
Could somebody try to install the google+ app? That is one of the apps I can't install.
Originally posted by nasosal View PostYou should go on for the latest update from ramos.cn. I've applied 21612, and installed some missing files from gapps to have Google maps, contact and calendar sync. Everything installs now, including google+
It is good to have update. I just installed it. For those who wants to install the update, I have the file here:
From the ramos update page, it says the update is ONLY for i9-gps version device. So, please check your device before you install it.
The ramos update page is here:
http://www.ramos.com.cn/download.php?action=view&id=452
How to use the update.zip file:
Just download the update.zip file and put it in your device's root directory. Then go to Setting -> About Tablet -> Software Update. The device will update and reboot itself automatically.
BTW, it would be nice if the OS can be updated too...!
There seems to be a new firmware 23085, checked using OTA, then googled & found the links here:
http://pan.baidu.com/s/1bnrPnkz
http://tieba.baidu.com/p/3278533782, used google translate, still downloading, no info on what has changed so far...
Update: Finished downloading & updated, all apps intact including gapps fixes, only need to re-root, antutu improved slightly:
antutuX from 18K to 19K+
Antutu from 20K to 22KLast edited by fztt; 07 September 2014, 16:44.
There are currently 1626 users online. 0 members and 1626 guests.
