Polaroid A8 Tablet
how to swap the memories
Originally posted by guessyet View PostImpactor is the program I have been using to root my A/S8.
I have been able to extract the partition images from the updated-google image. I modified the props to enable adb. I also was able to swap the internal sd with extsd to give me 32G of sd to use for installs..
I am currently working on the recovery.
elektrik.. maybe we can work together..
tried with ur modified still my pc wont recognize it
Originally posted by guessyet View Postthis is the google-update with adb restored. you install this with phoenixsuite and once the device is booted go into settings and do the following..
go to 'about tablet'
start pressing the 'build number' line over and over.. it will eventually count down and enable dev options..
once dev options are shown (dev option will be just above 'about tablet') press dev options.
disable adb if it is enabled and re-enable it. you will get a confirmation message.. press ok..
your computer should see the device and you will be able to run the impactor program to drop su into the xbin directory.. once impactor has finished install your supersu or superuser app.. and you are done..
http://www.mediafire.com/download/za...S-20130909.zip
Originally posted by Youngarson View PostWould that Cyanogenmod install work on this Tablet ?? Polaroid A8
Originally posted by andresinibus View Posti just downloaded the program and im wondering if you can give me a little guide on how to swap the internal sd with extsd as ive been trying to install nova 3 and i keep getting this error saying that i need an additional 822 mb of memory on my sd to install it on that note i noticed that the box says it has 4 gigs of memory* (* depending on how many apps you have installed) well for internal sd it only shows available 827.85 mb what am i supposed to do with that? thanks in advance
this is due to the pc.. i would look at drivers.. perhaps you need to uninstall your current android drivers and also uninstall your usb drivers.. and let your system pick them up again.. your usb drivers should be availible to the system without you having to provide them.. use one of the drivers i uploaded for the tablet driver. - BTW- if you are using one of the rooted roms i just uploaded 'adb notify' is disabled. the tablet will not tell you that adb debugging is on or connected to a pc in the status bar.
Originally posted by guessyet View Postthis is due to the pc.. i would look at drivers.. perhaps you need to uninstall your current android drivers and also uninstall your usb drivers.. and let your system pick them up again.. your usb drivers should be availible to the system without you having to provide them.. use one of the drivers i uploaded for the tablet driver. - BTW- if you are using one of the rooted roms i just uploaded 'adb notify' is disabled. the tablet will not tell you that adb debugging is on or connected to a pc in the status bar.
Originally posted by Deadphyre View PostI also have an A/S8 Polaroid tablet. Got it rooted and I've been looking all over the place for a CM9/CM10 ROM to install. Now...I know there isn't really one up but I'm more than willing to test a beta ROM. I'm fairly proficient and could most likely unbrick it should that happen.
But that 300-400 meg range is usually normal for an Allwinner firmware...
Originally posted by AManofFewWords View PostWell, I just got done compiling a CM11 ROM that is TWRP-flashable (well, it's CM). It's uploading on my drive, and I'll PM you when it's done uploading. It's a really huge zip (about 382 megs) I replaced some /system/libs as well. Hopefully it boots.
A/S8 simple root
I finally opened my tablet yesterday and updated it with the google bloatware from southerntelecom and for a while I thought I was going to be stuck with out working adb which means no root for me.
SnapPea gave me adb back and I believe impactor rooted me in less than 30 seconds!! Great feeling. I am new to this forum and overly anxious to get flashing on this tab.. Are there and Custom Roms someone would recommend? Mods/TWEAKS/Apps. I am a member over @xda and the only custom RoM I will use as a daily driver is CyanogenMod cm11 android 4.4.2 Most Stable) on my old a%s Droid Razr xt912 Spyder (omap) with @dtrail1 JBX-Kernel which you can do anyting you want with!!
Thank in advance..
Originally posted by 1droidmod View PostI finally opened my tablet yesterday and updated it with the google bloatware from southerntelecom and for a while I thought I was going to be stuck with out working adb which means no root for me.
Thank in advance..
I have a pre-rooted rom up that you can use if you want. Currently, there has been no modifications to the loaded apps.. they are the identical to the original google-updated version.. I did make a few changes to the android os in order for it to usable for development. Things like forcing adb access at boot and such.. There are several tweaks added to speed up response. I also added TWRP recovery with working touch because the original recovery system sucked. The rom can be classified as 'stable' as the original but is honestly more..
link to my AS8 pre-rooted rom thread.
There are currently 2950 users online. 1 members and 2949 guests.
