... Now when i plug it on there is no red light on stick and there is flashing light on power adapter. When i plug it in pc and press recovery button, pc dont do anything, like i didnt plug it.. Can someone help me with this.. i afraid my stick is dead :SS
MK809 III may be bricked :((( please help me
Today I flashed my MK809III with this : http://www.freak-tab.de/neomode/nhr_18_ap6210_1080.zip
... Now when i plug it on there is no red light on stick and there is flashing light on power adapter. When i plug it in pc and press recovery button, pc dont do anything, like i didnt plug it.. Can someone help me with this.. i afraid my stick is dead :SSTags: None
Try this - http://www.freaktab.com/showthread.p...400-All-in-One
But your PC must connect to your Device. Have you try the Pin 8/9 Mod ?
My is the same Board, see here - http://www.freaktab.com/showthread.p...l=1#post115713... TVDroid
> > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
The red led light indicates your stick is alive ... without it there would be no way to connect it to your PC .... if you short pins 8,9 that could bring it into what they call mask rom mode .. and then you'd need to flash a factory rom to it ...
1) make sure nothing is connected to your stick
2) short pins and power up ... (make sure the pins are shorted first)
3) power up again ... you should have your red light back .. if not you've probably got a brick
4) you can then use your otg port to flash a stock rom onto your stick
Help me please. When power on, MK809iii not start (no image on the HDMI port), but i have a red light on stick. When i plug it in pc and press recovery button, pc dont do anything. But if i short pins 8,9 PC found stick and inRKDevelopTool_v1.37 - "Found RKAndroid MaskRom Rock USB", but if press EraseIDB - "ERROR: Download boot failed". How i can flash it??? in RKBatchTool same problem -
**********Upgrade Action**********
**********Upgrade Start Total<1>**********
<Layer 3-2> Download Boot Start
<Layer 3-2> Download Boot Fail
**********Upgrade Done Success<0> Fail<1> Time<5070>ms**********
thanks!
Originally posted by ATB View PostThe red led light indicates your stick is alive ... without it there would be no way to connect it to your PC .... if you short pins 8,9 that could bring it into what they call mask rom mode .. and then you'd need to flash a factory rom to it ...
4) you can then use your otg port to flash a stock rom onto your stickMY MINI PC: C4,CS918,M8,M8C
Originally posted by Nikolay View PostHelp me please. When power on, MK809iii not start (no image on the HDMI port), but i have a red light on stick. When i plug it in pc and press recovery button, pc dont do anything. But if i short pins 8,9 PC found stick and inRKDevelopTool_v1.37 - "Found RKAndroid MaskRom Rock USB", but if press EraseIDB - "ERROR: Download boot failed". How i can flash it??? in RKBatchTool same problem -
thanks!MY MINI PC: C4,CS918,M8,M8C
Originally posted by darekmarta1975 View Postwhen purchased MK 809III because new vehicles are new loader and not you upload a different firmware
Nikolay try another firmware, Like Neomode v1.0 or 1.7??
try flash with stock rom...??
There are currently 2726 users online. 0 members and 2726 guests.
