I found this over on the XDA site. It is a method for making Android think that the external and internal SD cards are reversed. So if you have a 16 MB external card, it becomes the internal memory for Android and our paltry, built in, internal memory shows up as the external SD card. It requires editing two lines of code. Instructions are at this posting
How Do I Easily Move Apps to External Micro SD card on the PMID701C?
How to swap internal and external SD cards
Yep...that's pretty much the way it's described here.
Originally posted by db8max View PostI found this over on the XDA site. It is a method for making Android think that the external and internal SD cards are reversed. So if you have a 16 MB external card, it becomes the internal memory for Android and our paltry, built in, internal memory shows up as the external SD card. It requires editing two lines of code. Instructions are at this posting
http://forum.xda-developers.com/show....php?t=1642006
The built in 2GB SDCARD and 16GB (your example) EXTSD are both external storage. SDCARD just happens to be the default storage location.
Apps are stored in the (even more paltry) 1GB Internal Data area which is not affected by the swapping of SDCARD and EXTSD.
Even if you move what apps you can to SD (SDCARD), you will probably run out of Internal Data space before you fill the 2GB SDCARD. Once Internal Data is filled you are done adding apps (it doesn't matter if SDCARD has 2GB, 16GB or 32GB free).
If you don't do this for the size of the default storage, then why would someone do this at all? Because this makes the default storage location removable!
App Backup & Restore, MyBackup Root & Titamium Backup all default to /mnt/sdcard. So when you do a backup, it would then automatically go to your removable card. When you are done with your backup you can remove the card and copy it to your PC, drop box or some other safe place.
I just reflashed my tablet and swapping SDCARD with EXTSD was one of the first things I did once it booted. Then I installed Link2SD so I can use the 1GB ext2 partition on my removable 16GB SD card to truly move apps to SD if I care to.
Jim
Originally posted by kc9hi View PostOops... Link2SD doesn't work with SDCARD and EXTSD swapped
I guess I won't bother now
link2sd. update
The problem I had with access to the primary partition after installing the app was that I needed to reformat.
However, when I put the sd in the computer I to do so I lost the 2nd partition. Minitool now sees only an 11gb partition on a 16gb card! Partition recovery didn't find it and now link2sd doesn't either. Doh!
On the slightly brighter side I've got it back the way it used to be. Deleted link2sd.
Prob all user error. Good luck!
Look up info on a built in application in windows called DiskPart. It is a command line tool and you can fix partition tables with it. I've fixed a number of flash drives that I thought were dead with that.
Sent from my ADR6400L using Tapatalk 2Polaroid PMID701i 13
Stock Rom from S.T.'s site
Fully rooted
Google's Market installed
Originally posted by lukenova View PostLook up info on a built in application in windows called DiskPart. It is a command line tool and you can fix partition tables with it. I've fixed a number of flash drives that I thought were dead with that.
This is a VERY POWERFUL utility, as one of the 'DiskParts' that might get 'fixed' could be your C: drive Windows or recovery partition.
If you are in ANY WAY UNSURE about EXACTLY what you're doing with this utility, you don't have your data backed up either in the cloud or with Redo Backup or another utility, and/or if the data on your HD exceeds the cost of replacing an SD card, DON"T PLAY WITH FIRE.
You have been warned...
73 DE N4RPS
Rob
excellent advice from bob/ more slack for us!
Hehehe, reminds me of dos fdisk on a 25mb hd.
Getting off topic, I should prob search for forums on each app I have questions about. User manuals are not extant.
Seems strange that link2sd could hide a partition so well that minitool, which created it, cannot find.
I'm cool with the reduced partition for now. Maybe I'll bork some more stuff up later.
I'll wait for a sdcard unmount, repartition internal mem to full 4gb, mount extsd as sdcard solution.
To grok or not to grok, that's the congestion.
Thanks Single Dad
Hi Guys,
I am completely new to this site and forum, I only found it because I just got a new Onda Vi10 Delux with the new android 4 operating system.
My 16gb SD card was completely invisible because of the stupid internal Sd partition, and I don't think I would have found a solution ever if it had not been for the solution posted by you Single Dad.
So thanks a million from an unknown newbee who's bacon you saved.
Totally cool dude you are
Still Confused
I used single dad's solution to this vexing problem but I am still not getting "easy" results. So from what I gather, this came with 4 gigs of internal storage. The internal was partitioned into 2 2gig partitions and one is "tablet" or "internal storage" and the other was labeled as "SDcard" or extSD". The true external SD card was labeled? Anyway, I've tried moving apps to the external SD (now internal?) using Titanium Backup Pro and the App manager, and every way I try it the apps are still on the internal memory and not on the true external SD card. I'm giving up for now.
Link2SD shows file locations that OS does not.
Pics show Link2sd as on my phone with Froyo 2.2.2 -- rooted and stock rom on Samsung T589 [Gravity Smart / Galaxy Q in Canada].
1. Apps are reported as both internal as expected by OS [ in /data/app],
and as stored by L2sd [onto a separate 599mb partition on sd card, ie, /data/sdext2].
2. L2sd reports true usage of the various partitions. You can see that 61.72 mb of downloaded apps are on sdext2 [instead of on /data/app].
No other changes in OS were needed.
Rob / jrm
_________________
N7P rooted w/ Finless #1011V1.5 (was V1.4)
what happens to the second internal partition and the apps it contains?
Thanks very much for this fix because I've been dying to learn how to do this and am ready to try it for myself. I do however have a couple of question:
1: what happens to the second "partition" in the internal memory once I've modified the vold.fstab file and rebooted? Is the internal memory now just one large parititon?
2. If there are still two partitions, and from reading this thread it sounds as though there will be, is the second one still accessible and if so, how?
3. If I already have apps on this second internal memory partition before I modify the vold.fstab file, once I reboot can I then simply use Titanium Pro to batch move them to my external sdcard the way you'd normally do without this pesky second partition? Or do I need to squeeze those apps back onto the first partition, do the mod, reboot and then move them to the external sd card? I see that at least one person has reported a problem with uisng Titanium to do this
Thanks - Gil Theissen
There are currently 2245 users online. 5 members and 2240 guests.
