This is now v1.4a. I posted an updated ROM to fix a problem users found with default apps not working.
If you view post #140 in this thread, some users are successfully running this ROM on the Sumvision Cyclone Voyage 2 9.7" (version released in the UK) which should be a rebranded version of the Pipo M6 Pro. Flash at your own risk, but know that others do have it working.
I've started using a new process in making ROM's which involves adding a couple of features you may find handy.
First of all, in an effort to get a working CWM Recovery for these Pipo tablets, my development collegues here at Freaktab have devised a process to automatically install CWM after the first boot. The stock recovery will appear on first boot and format all of the necessary partitions, then the system will automatically install CWM Recovery after the first boot. So let the tablet set of a minute or two while this is being done before you reboot. From then on, when you reboot to recovery you will be in CWM.
Next, there is a feature to automatically install any apps you have in folder called "autoinstall" on your external SD card. Just load the apk files you wish to install in that folder and watch them populate to the app drawer immediately after the tablet boots for the first time. CWM will install last, so just wait about a minute after you see your last app populate to the app drawer. Now there are some limitations to this feature. First, you must have no spaces in the file names of the apk files. Just use your explorer app to rename the apps to remove spaces. Also, I wouldn't just install EVERYTHING from autoinstall. This is for utilities you need immediately. It's still better to restore your apps/data from a Titanium Backup. Some apps don't like to be installed this way. For instance, if you have an app like Titanium that has a key app to unlock all the features, you can install Titanium, but NOT the key app this way. Those key apps prefer to be installed via Google Play Store or from a Titanium Backup. Just experiment with it and see how it works for you.
Thanks to Finless, I've figured out how to keep the provision services from running...to try to install a bunch of bloatware that I've removed. Now it boots directly to the launcher.
As usual this ROM is:
Rooted
Debloated
Init.d Support
Busybox Support
English Default
Working CWM Recovery
2, 4, 6, 8, or 12gb user app space by changing parameter files
Boot Animation by Tattman65
Reboot app by Petrus
Updated First Time User's Guide
Rockchip driver installer app is now included in the kit
Download
Now v1.4.2 is available with:
Updated Google Apps to most current versions
Updated SuperSU and binary
Deep Sleep fix applied
Download v1.4.2
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
