Pipo M8HD RileyROM 1.3
    I just made an update to the ROM with the following changes:
    1. New versions of all included Google Apps, including the Play Store.
    2. Added the lib file which fixes the deep sleep feature for 3G versions.
    It still included all of the other features I mentioned in post #1
    This is v1.3.1
    Download
    Let me know how it works for you.
    Randy
      Originally posted by stevejc View Post
      I have tried to change boot.img (init.rc) as Bob do in Finless M9 ROM and I get 0.3% per hour with wifi on but not running
      Will try with wifi off this night
      Thanks a lot
      What are the changes you made? Can you post boot.img?
      Sent from a mobile device - apologies for any crap
      Donate to Finless
        You can try this one
          Just got home - thanks for this Randy.
          I've patched the kernel and installed it on the old image on my device
          Antutu 20268 -- stock + 720 RAM
          unstable on my M8HD -- 1.7 GHz + 720 RAM
          I need to fully charge my tablet before flashing the full image
          I have tried 'stock+ 720 RAM', but the tablet doesn't boot.
          Do you have another one that I can try?
            That's the mildest change there is
            Donate to Finless
              Thanks a lot
              I swapped to the alternative RIL but still 1% per hour WITH deep sleep. I have wifi set to turn off during sleep. Only difference I can see is I now get a message, "no sim installed" on lock screen.
              I'll try and borrow a micro USB and flash the boot.img you supplied
              Donate to Finless
                Hi, I have tried cpustock_gpustock_ddr667 (with voltage equal to stock)
                And it's working well : Antutu 19830
                For DDR720, I should surely increase voltage to 1300, but not need
                  Steve, my fault. i forgot that I habitually undervolt the 720 MHz RAM to 1.2v because I know it works for me. Hence you should try 720 MHz @ stack (1.25V) before going higher.
                  Have flashed your boot.img now and will test battery drain going forward. Thanks for that.
                  Donate to Finless
                    So I can see that you've commented out services Muxd6/7/8/9 and replaced the binary servicing the ril-daemon with /system/bin/rild instead of rild3.
                    The question is, does this still allow 3G or does this remove 3G altogether - Testing now!
                    Donate to Finless
                      Hi, I have a wifi version !
                      I take the wifi modifications made by Bob so for 3G; don't kown !
                      I will check what he has done
                        Posting this via 3g. It took almost 20 mins to swap from edge to 3g but it did eventually
                        Sent from my M8HD using Tapatalk
                        Donate to Finless
                          Finaly best result with undervolting CPU and it goes to 1704
                          MHz mV
                          312 850
                          504 875
                          816 950
                          1008 1025
                          1200 1100
                          1416 1175
                          1704 1275
                          GPU Stock
                          and
                          RAM
                          MHz mV
                          666 1250 (stock)
                          not stable at 720
                          Antutu : 20500
                          You know what : I'm happy
                          Will see battery now..
                            How bizarre my CPU will not run stable at 1704 but RAM will go to 768 MHz at 1.2v
                            Donate to Finless
                              Yes, for me, I need 1.3v to achieve RAM 720 !
                                Oh I've just tried to access a USB drive via otg but getting nothing. Have tried two now and both don't mount. Just me?
                                Donate to Finless
