The SDK2.4.0.img should be flashed by RKBatchtool.exe could be found on Riley's roms "Alternate reboot to flash tool" folder.
If you would like to flash the SDK2.4.0.img with Riley's ROM_Flash_tool first you need to extract it to get a proper system.img with imgRePackerRK. After the extraction you will get a system.img which could be placed in the RileyRom folder.
The U6's manual flash mode could be triggered if you power on the device with volume down pressed the USB should be conencted all the timeSorry for the late response.
