Sent from my Transformer TF101 using Tapatalk 2
PMID701i Stock Rom
Originally posted by jtrosky View PostHas anyone tried the "official" ROM from the ST website yet? Just curious as to the results... Sent from my Transformer TF101 using Tapatalk 2
Originally posted by chessir View Posthi, I would like to download the orriginal rom. I went to the southern telecom site (polaroid tablet) and all I can see is manual. Can you please post me the URL where I can download the rom?
Here ya go... This page has the firmware flashes for all the different 701 series tablets:
There are several different incarnations of the 701i, so be sure to look at the label on the back of your tablet. That way, you'll get the right file for your hardware.
73 DE N4RPS
Rob
I can't flash
I just bought this wonderful little tablet (701C) at BL today I can't seem to flash to the ICS rom I downloaded the Live Suite and the PMID701i.img when i get to the 4th step my pc just tries to look for a driver and fails and the tablet stays black can someone please help me. thanks in advanceOriginally posted by shawnbusker View PostI couldn't have made this ROM without the help of ghostfayce (stock rom img dumps). This rom can be flashed with Live Suite and does not use any Onda firmware files.This rom is the same rom that comes preflashed on the PMID701i when you first buy it at the store. So now you can go try new roms without the worry of not being able to return to factory defaults.
Tutorial:
1. Download Live Suite.
2. Turn off your Polaroid Tablet
3. Select the PMID701i.img from inside Live Suite.
4. Hold the second button from the bottom and plug your tablet in. (Recovery Mode)
5. Select Format Upgrade.
Live Suite
ROM DOWNLOAD
Originally posted by James View PostI just bought this wonderful little tablet (701C) at BL today I can't seem to flash to the ICS rom I downloaded the Live Suite and the PMID701i.img when i get to the 4th step my pc just tries to look for a driver and fails and the tablet stays black can someone please help me. thanks in advance
Jim
Originally posted by kc9hi View PostYou didn't mention which version of Windows or LiveSuite you were running. Older versions of LiveSuit required you to force the correct driver using SuperOneClick depending on your OS. Your best bet is to make sure you are using LiveSuite v1.07 or v1.09 to get the correct driver for you OS without needing SuperOneClick.
Jim
Originally posted by James View Postthe livesuite version i have is the one that was provided on the op im not sure about wat the version number is as for windows i tried it under 7 and vista
Or you can get the LiveSuite v1.0 from Southern Telecom/Polaroid. Just download the correct firmware for your tablet model (LiveSuite is included in the ZIP)
Jim
FM45 -- Thank You!
Originally posted by FM45 View Post@yebyen
If you want play store try these files; they may help you. Read me included.
netload.in ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf netload.in alles. Wir hoffen, dass Sie hier das Gesuchte finden!
-=FM45=-
Tutorial:
Live Suite
ROM DOWNLOAD
The ROM download doesn't seem to work anymore...
There are currently 4324 users online. 1 members and 4323 guests.
