Very tempted but unsure about A31 chipset and how well it will perform
New -- CS918S
Originally posted by gjs999 View PostAn update to the CS918 -- the CS918S -- using the A31 chip set instead of the RK3188 but with a 5mp camera or 3g module -- new firmware due out any day with Gamimg Motion .
should performe quite well. Look on youtube. I'm still looking for its firmware to flash on my measy u4k.
I also.. checked out this cs918s unit.. (aliex 45euro)
Some youtube vids are lies.. it shows a cs918 unit.. its missing the android logo on the box
-same antutu score as rk3188 was the clue (1ghz a31 vs 1.6 ghz )
-- geekbuying desc.. kuch.. 4k using mali400 lol
I was thinking about buying one...( for fun )... but no reseller could provide a firmware for the unit
-with-out fw.. i would not even consider buying one
Originally posted by mitchell4you View PostLol.. look at the desciption... it uses mali400mp4 ( not powervr )
This device has just hit the market. Allow it some time and you'll see the fw.
Originally posted by JDfense View PostThis device seems not to be a similiar to the cs968 ?
I move it the cs918 thread.
JDfense
So,
Is a better place for this thread.. jdfence
Small note.. the build.prop has no stagefright entrys.. like my mk823 does
[exracted img.. to compare with my own unit.. for fun ]
But under lib there lots of libstagefright files..
It has 3g support for..huawei EC1261 E353 E1750 [3g_dongle.cfg]
Extracted apk files.. youtube 5.2.27 - vidon.me tv [if someone need a file pm me ]Last edited by mitchell4you; 12-10-2013, 22:27.
Originally posted by mitchell4you View Posthttp://www.mediafire.com/download/eh..._20131202_.rar
Geekbuying saves the day
Stock Firmware for the cs918s.. now i can buy a unit.. cheersLast edited by ADD; 12-13-2013, 15:36.
This device performs very well. I have used both this and the original CS918 - The CS918S performs much better (IMO).
I have purchased more than one unit - they came with:
Firmware Version: v1.0rc3
Kernel: 3.3.0 ck@ck-desktop #42
Has pre-installed launchers... Im thinking this is not the stock ROM.
I'm having problem with one of the units freezing/restarting after about 2 minutes of use...
Im going to try flashing the stock ROM posted above.. Hopefully that will fix the issue.. I am having doubts though as the other unit has the same ROM and runs fine.
Any suggestions? Could it be overheating?
Originally posted by samrambo117 View PostThis device performs very well. I have used both this and the original CS918 - The CS918S performs much better (IMO).
Originally posted by ADD View PostI guess overheating is one of the problems for A31. So, try modding.
What do you suggest I do to fix the overheating problem?
Originally posted by samrambo117 View PostI don't believe so.. Because the other two A31 devices (CS918S) are running fine.. I think this device is a one off problem.
Hello @ all
I am new to the Android Media Player.
I have the CS918S.
Mine only has XMBC 13 alpha 4, and I think I need Alpha 7 or higher to use the Hardware decoding available.
I downloaded the Firmware from the link above, but I do not know how to install.
If anyone would be so kind to teach me?
Thanks.
There are currently 2522 users online. 4 members and 2518 guests.
