K-R42 with PCB TN-BX09_V2.1 1340
    It is version from lewy's rom.
    You can pull recovery image from old Wasser rom (1.2.1) and flash its recovery on top with RK android tool (finless tool)
    I have the rule after flash: flash it and after success immediately pull off cables. Then connect to Tv and boot
    Wysłane z mojego iPhone 5 przez Tapatalk Professional
      Some possible help...
      Hi Gents,
      I bought the practically identical Upmost ATV300 ( http://www.upmost.tw/gb/product_detail.php?prod_id=1059 ) here in Taiwan on Saturday. I've rooted it, installed CWM and created a backup. If you're interested, how might I share the backup/important files with you? It's 720p only but is rock-stable. Btw, the backup might have my account info in it; if so, how to remove it?
      A couple of familiar photos here:
        Thanks for link
        This is the first time my 2.1 device with wifi 8188etv has worked....only thing is now the play store wont allow me to load certain apps like speedtest.net...says my device doesn't allow it...why / how does this app work with other firmware's and not this one....is there anything I can changed to get it to see me as a good device in a good country?
        Do I need to edit some files for google to see this device as able to run all?
          Originally posted by crshNbrn View Post
          http://www.upmost.tw/gb/download_det...0&prod_id=1059
          Change build.prop to the one from lewy rom. Or apply finless bob gameloft fix.
            Thanks Mikel and thanks Crshnbrn & you're welcome. I had no idea about that download! Now let's hope we can get one of these lovely custom roms working with it
              I will look at this rom and probably be able to run HFW on its base.
              Anyone want to test it?
                You got it, mate : CLAP
                  Unfortunatly I am not able to unpack the firmware file.
                  PolarBear, can you provide me your CWM backup?
                  There is a chance that I can work on this, but a loader problem version will be still unclear this way (hopefully there are only two loaders).
                  If you can you can also dump partitions as in guide in K-R42 section.
                    which guide?
                    Hi Mikel, got a link? Sorry, can't find the guide you referenced. Also, which parts of the backup do you need? Just winrar the whole folder?
                      I need all of this to be done:
                      is custom roms like justXBMC, wassers rom versions or HFW works for you? I mean it just has to boot. No Etherent or wifi is needed.
                        UH OH
                        I don't even know what HFW means & XBMC is useless to me since I don't watch TV; all I will use my device for is downloading and teaching. Also, the process of dumping roms and building imgs is quite beyond me at this point, and since I work and have a family, I don't think I can handle it any time soon. I'm quite willing to help in ways that aren't so time consuming, however, and I'm also thankful for those such as yourself who contribute so much. Thanks & apologies.
                          There is a way u can help me without sacrificing much time.
                          Can you connect your device to PC and tell me what boot version you have?
                          If there is no visible in RKbatchtool I will provide any other rock chip designed tool to see that.
                          I think ROMs don't work because if loader version (since parameter file and etc can be imported from stick rom)
                          That's how I made hybrid firmware working on justXBMC base.
                            fix for me
                            Fixed My device dont know why but do know how
                            rk3188 v2.1 with an 8188etv wifi
                            always had issues with wifi working and many firmwares not even the mfg firmware.
                            Fix for ME
                            Loaded this firmware
                            MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
                            then I did the erase idb then load
                            (new and old kernal for this k-r42) both 1080 work.
                            Dont know why both work but they both do for lan and wifi .... but store wont let me get certain apps like speedtest.net
                              Fix for ME
                              Again, you have to pull build.prop from HFW rom for example. I will post it tomorrow when i will have time (16.00 GMT +1)
                                Hello to all!
                                I already bought (in Poland) tn-bx09_V2.1 and had some problems with run wasser's fw like others.
                                I takes all one day but I found a
                                solution to "fix" it with smooth run and support xbmc 13.0 Gotham alpha11 version with 1080p movies even by LAN cable.
                                This kikat version ( http://www.freaktab.com/showthread.p...roid-4-4-kikat ) by deafult works great but hangs after reboot - never ending story with recurrent error on top about stop phone application. I don't remember exactly.
                                I've used kernel-ut1.img as default and get speed like 140% with comparsion to lewy's K-R42_HFW_1.2.0_Final_1080p (only one another working fw with this pcb).
                                X92 3/32 Android TV Box with Ugoos AM3 Firmware
