T-R42 B351 v1.1 PCB | Stockrom | Rooted | OC-Kernel and more... gnm!
Can you see if you have the driver located in /system/lib/modules/rkwifi.ko? I think your system file structure is corrupted, try to do a full flash which will replace all the new files. Make sure you flash the full rom the correct way. Using the appropriate tool and a full legit rom. If you're creating your own zip and flash with stock recovery you are chasing your tail. You mentioned that your pc unable to see your device after a bad crash, your recovery/bootloader/file structure maybe in a unstable state. Take my advice do it right and if the issue stills existed then your hardware maybe bad. I also considered that your recovery is not good, then you keep flashing bad stuff. You need to reflash cwm so at least you have a good recovery and use cwm to flash the rest...the right way.
i found my board on homepage of sztena (the producer), so i contacted them....
Dear SZTENA team,
i bought in german by a chinese company a TV box. Opening it i found out it is B351_V1.1 from 2013/08/30. B351 is a market name on your homepage.
Please be so kind to give me some update help.
--> Latest-SW
--> original SW
--> Revitalising by SD card...
There is a bigger group around who evolve to have problem with this device. Any support in this direction would be appreciated. So far useful informations come from geekbuying ...
Marketing help might also be a focus also for non chinese speakers, specially a "working" firmware for kitkat ;-)
Best regards
Hello,
I am bruce ,come from Tena sales term.
I am glad to help you.any question,tell me pls.
Best regards.
methods: http://pan.baidu.com/s/1mg9cPPA
Flash tool: http://pan.baidu.com/s/1sjuF905
original SW http://pan.baidu.com/s/1jGt7Qvk
Latest-SW http://pan.baidu.com/s/1bneTej1
Bruce.Huang
Tel:18680356448
QQ:2683685889
Skype:bruce.huangchina
E-mail:[email protected];[email protected]
Web:http://sztena.cn.alibaba.com http://www.sztena.com
Add:9Floor Mid-Wing, IER Building, South Area, Hi-Tech Industrial Park, Shenzhen, China
High bruce,
thx for your kind response.
1.) Does it mean B351_V1.1 is a RK3188T (with a little bit less frequency).
2.) The Update SW has NOBT in the name. Does it mean no Blue tooth? Is there a change history.
3.) Do you have a SD card image to revitalize the unit without the need of a computer? Some people i know have a loss of USB functionailty...
4.) Is there a kind of forum to be updated with the development progress?
Your kind support is much appreciated.
Best regards
I am sorry to give you any question of my products.
1.)yes,it is RK3188T;Reduced frequency and power consumption, performance and experience.
2.)yes,Your machine with BT? We have two versions of the software
3.)No.
4.)No,Have not,maybe in the futher
maybe a specialist can get more infos there, directly from supplier.....
There are currently 1644 users online. 3 members and 1641 guests.
