T-R42 B351 v1.1 PCB | Stockrom | Rooted | OC-Kernel and more... gnm!
    Hi Folkz.
    *NEW*21.12.2013
    OC-Kernel-Pack *KLICK be careful with that what you´r doing!!! Stock is cpu1608 | gpu600 | ddr400
    And don't forget, it's all your own risk!
    *NEW*
    20.12.2013
    T-R42 v1.1 Stock Root OC *KLICK
    -Rooted
    -Reboot App
    -Adobe Flash Plugin
    -Patched libmedia | DTS/Dolby HDMI Passthrough in XBMC
    -Patched V-Sync Overclocking-Kernel CPU@^1704mHz | GPU/DDR@^600mHz | THE SAFE WAY
    -Round about 20000 points @Antutu Benchmark
    -720p UI | 1080p Output
    -Debloated APKs separately packed | Stock Apps *KLICK
    -Tweaked build.prop
    -Spoofed as Galaxy S3 (by lewy20041)
    -New Base from DG10 Dongle (Thx to mg0179)
    THE FIRST BOOT NEED LONG TIME TO LOAD ALL APPS!
    AFTER A REBOOT AND ALL IS ONCE LOADED - IT WORKS FINE!
    Use No-Frills Cpu Controll to adjust frequencies!!
    All content is for the B351 v1.1 PCB!
    (v1.0 not tested!!!)
    *OLD*
    T-R42 v1.1 Stockrom *KLICK
    from Geekbuying untouched.
    Stock-Kernel-OC´d cpu@^1704mHz gpu@^600mHz ddr@^667mHz *KLICK
    It scales @cpu from 504 mHz and make round about 20000 points @Antutu Benchmark.
    The Voltage Setting are safe, but don´t cry if brick.
    Over and out...
    it really works
    it really works
    Originally posted by genom View Post
    Hi Folkz.
    T-R42 v1.1 Stockrom
    T-R42 v1.1 Stockrom rooted, cleaned and with CWM-recovery is in work.
    Over and out...
      that's the firmware I got from the manufacturer
      please tell me if it works
      http://pan.baidu.com/s/1kpZw8
        This seems to be the firmware for the 3188T.
        I take a look...
        edit:the kernel must works 4 you!
          I take a look...
          Hi Folkz.
          Over and out...
          Hello
          After the firmware need to separately install the kernel? Or kernel is stitched together with the firmware?
            Originally posted by Sumash View Post
            Hello
            separately
              separately
              How can i flash separately ?
                Need to flash the kernel separately prog ROM_Flash_Tool_137. Rename the desired kernel in kernel.img and throw in a folder FinlessROM, run the file ROM_Flash_Tool_137.exe, remove all jackdaws except kernel, connect the console to the PC mode firmware and click Flash ROM firmware wait until the end.
                  *NEW* Rooted Stockrom OC´d
                    It is not realy 1920 pixel. it is my fault?
                      The UI is scaled 720p but Videoutput is 1080p like the Stock.
                        Can you make a new firmware what in the Ui is 1080p ? (sorry my English)
                          no 1080p ui in the moment...
                          Videooutput is 1080p and im still learning to get a 1080p Userinterface.. .
                            Question
                            Hi Genom,
                            I have a android smart tv box labeled B351_BT. The pcb inside is marked B351_V1.1.
                            Can you confirm that your image is working with this box.
                            Thanks in advance,
                            Louk Seton
                              Originally posted by louk View Post
                              Hi Genom,
                              Thanks in advance,
                              Louk Seton
                              Confirmed! (see pic in first post)
                              I have the same box.
