.gif)
Download: http://www.mediafire.com/?9gqiwr9x9xl95
V6_SUPERCHARGER FOR ALLWINNER A10 ICE-CREAM-SANDWICH TABLETS.
PLEASE READ THE GUIDE CAREFULLY BEFORE APPLYING THE SCRIPT.
FEATURES:
1. Smooth and Fast Re-Draw of UI and Internet Browser.
2. Complete Memory Management Script. Not a Junk Android Manager.
3. No need for those crappy Android Task Killers applications.
REQUIREMENTS:
1. Fully Rooted with Superuser and BusyBox 1.19.4. If you install Root-Script:
2. Please update BusyBox Free (Stericson) to v7.8.2 on PlayStore.
3. Proceed to BusyBox Installation. Install BusyBox 1.19.4 to SYSTEM/BIN directory.
4. Reboot Tablet.
5. Launch SuperUser and goto Preferences. Tap "SU Binary Update"
6. It will fail on 1st time, just "Try Again" until all text are "Green"
7. Reboot Tablet.
8. Internet Connection for PORN! -LoL
INSTRUCTIONS:
1. Connect Tablet to PC powered-ON and enable USB Debugging & Stay Awake.
2. Run V6_SuperCharger-Pull-Push-Script and Follow Instructions.
3. Select Option-#1 first and when done, do not EXIT the Script yet!
4. Upload Services.jar inside "ICS/default" folder to HTTP://ANDROID.MIMIC.CA
5. Download the Modified Services.jar and put inside "ICS/modified" folder
6. Proceed to Option-#2 and Reboot Tablet.
7. On your Tablet, download and install "Script Manager by DevWom".
8. Launch Script Manager and tap "Browse as Root" and check "Do not ask again".
9. It should ask for SU Permissions. If not, the script won't work.
10. Locate the "V6_SuperCharger_Update9.sh.pdf" and tap to open using Script Manager.
11. Once you get on V6_SuperCharger_Update9.sh.pdf menu, TAP to ENABLE [SU]
12. Leave the OTHER options at DEFAULT. Hold your Tablet to PORTRAIT MODE.
V6_SUPERCHARGER MENU #1: BASIC SETTINGS
1. TAP the [RUN] button. V6_SuperCharger_Update9 Script will now RUN.
2. If asked for "Scrolling Speed", select [FAST]- Type= 1
3. If asked to "Disable Animation", select [YES]- Type= Y
4. If asked to "Apply SuperMinFree Calculator Settings", select [YES]- Type= Y
5. Follow the succeeding "Script Instructions" and it will ask if you want:
6. TO perform "SuperClean and Restart", select [YES]- Type= Y
7. Tablet may look like in Boot-Loop, but it is not. Just Try ON/OFF atleast 3x.
8. If successful, you can skip performing V6_SuperCharger Menu #2.
V6_SUPERCHARGER MENU #2: ADVANCED SETTINGS
----------If asked for "Scrolling Speed", select [FAST]- Type= 1
----------If asked to "Disable Animation", select [YES]- Type= Y
----------If asked if "Launcher is at Home", select [YES]- Type= Y
----------Press any Key to Continue. If Browser pops-up, just press BACK once.
2. On V6_SuperCharger MENU, select [SuperCharger & Launcher]- Type= 1
3. Wait until it finish and Press any Key if asked to do so.
----------If Browser pops-up again, just press BACK once.
----------You'll be redirected again to V6_SuperCharger Menu.
4. On V6_SuperCharger MENU again, you have the Following Options:
----------If Tablet has 512MB RAM, Select [Super UL -512 HP] Type= 7
----------If Tablet has 1GB RAM, Select [Super UL -1000 HP] Type= 9
5. Wait until it finish and Press any Key if asked to do so.
6. You'll see something like "100% SUPERCHARGED" if its Successful
----------Select [SuperClean and Restart]- Type= 30
----------We're not DONE YET! Please proceed to next Instructions:
LOAD 99SUPERCHARGER.SH ON BOOT:
1. Launch Script Manager and press Back Key twice until you reach [/] Directory.
2. Open /Data and look for 99SuperCharger.sh, tap it to select and run using Script Manager.
3. Select [SU] and [Boot] and hit the RUN button. After finish, just close it.
4. Enjoy V6_SuperCharger - Super-Saiyan Mode.
5. Do not uninstall Script Manager. It is used by 99SuperCharger.sh every Boot-up.
DEVICE NOT FOUND ERROR?:
1. Extract USB_Driver to a Folder and Connect Tablet to PC powered-ON.
2. Go to Device Manager. Check for an Android Device with Exclamation Point [!].
3. Right-click Android Device and click Update Driver. Locate the USB_Driver Folder.
