[NETFLIX FIXED!!] Simplified V6 Supercharger for Allwinner A10 ICS[RECOMMENDED!]
    Originally posted by elektrik View Post
    From where just out of curiosity-not ST...?
    From Allwinner down the line to people compiling android for their devices.
      Ok I'm confused. Does this pertain to my 701i X10 or is it compatible with it?
        Any news on this? Any links to try downloading?
        https://public.bay.livefilestore.com...ion.png?psid=1
          Wanted to say thanks to artistlogic for this recommendation!
          I was really disappointed with the performance on my 701c on ICS. Lots of lag. Poor streaming. The comcast player app would not even load. So I "downgraded" to Shawn's bloatware free 2.3 firmware. I upgraded market using an allwinner a10 script found on another website. Everything was significantly more "snappy" but Youtube still would stutter.
          So after reading this post, I found the original post on XDA and followed directions for gingerbread roms. I used busybox 1.19.3. (1.19.4 was not even recognized by the v6 script).
          The v6 supercharger script made the tablet even more "snappy" when switching between apps and youtube video's play perfectly now.
          Thanks again.
          Sorry, Here's the link:
          XDA V6 Supercharger original Post: http://forum.xda-developers.com/showthread.php?t=991276
            Thanks again.
            Ok, so don't be stingy, provide the link! :-)
              Doesn't work with Southerntelcom firmware
              I applied the Supercharger update to my 7XC. Couldn't tell if it helped but it definitely didn't hurt. I then applied the Southerntelcom firmware update in order to fix the problem with the Google GPS location not working. I then tried to apply the Supercharger update and after two failed attempts, gave up. It doesn't appear to work. I could boot up but Wifi would be disabled, when I turned it back on, the tablet would reboot.
                Did you happen to check if Netflix works on the PTAB7xc with this? I had no glory with LiquidLimez fix as far as Netflix is concerned. I was able to get Netflix working before updating to the v3 firmware. No luck now. Obviously it is capable but software is causing issue.
                UPDATE:
                Got Netflix working by using an older apk (1.8 I think? Don't have tablet on me)
