I will also ask to not post about this firmware anywhere else than freektab to make sure that firmware is stable and noone unexpirienced flashed the firmware and complain. That said lets go to the firmware futures
changelog:
-based on latest stock firmware
-debloated (striped down to minimum, all deleted orig apps are in downloaded package if anyone need them)
-rooted
-new wallpaper
-"x" bootanimation
-replaced hidebar and power button on systembar
-spoofed as galaxy s3
-some wifi and streaming fixes in build.prop
-kernel choice 720p or 1080p (default 720p)
-720p freq changed (516Mhz-1600) + vsync fix
-1080p freq changed (1008Mhz-1600) + vsync fix
-new option in settings "advanced"
-resolution switch in settings< advanced
-update option under settings< advanced
-init.d supprot (nfs,smb,static mac scripts under etc/init.d "just edit and set permisions as 755)
-nfs support
-new folders under /mnt/
*NFS_1
*NFS_2
*SMB_1
*SMB_2
-new modules added:
*nfsx4
*md4
*virtualtouch
*tun
-"new app" youtube for google tv 1.7.3 (realy hard to get)
-"new app" es file explorer
-new webcam driver (better support for logitech webcams)
-gameloft fix
Download:
pass:
geekbuying.com
