it is made from archos and rebrand by auchan, sold in they're store
good specs
Processador: 1.6 GHz Quad-Core/RK3188
Memória RAM: 2GB
Armazenamento: 8GB (expansível até 64 GB – cartão microSD)
Ecrã: 9.7"multitouch 2048x1536 px – IPS technology
Sistema operativo: Android ™ 4.2 Jelly Bean
Camara: Frontal e Traseira de 2MegaPixeis
Ligações: Porta micro USB / Combo jack (3.5 mm) / USB 2.0 / saida mini HDMI
Material de fabrico: Alumínio
but lacks of software and cpu-z says that all cores are limited to 816 mhz.
i thinks it's a rebrand of archos platinum 97b http://www.archos.co...m/specs.html?#a
because:
-specs are the same
-they looks exactly the same
-lots of "archos" brand name in infos
-name similar (archos 97b-qilive 97r)
-and finally, behind this tablet in very small characters there is a code: model number - ac07bpl. If you search this with google you will find a few result and all points to archos 97b.
Any of you guys can confirm this? And if so, wich is the best rom to flash on it?
thanks
ps. if you need any more infos just ask
edit: apparently archos rebrand onda tablets, but i can find a similar onda to this 97b
