Features
1. Overclocked GPU to 400 mhz(default 266 mhz)
2. Includes working XBMC Minix Edition Beta 2
* It has been optimized for the Rockchip VPU, so you'll get better video performances than on a generic XBMC.
* VC1 and VP8 accelerated.
* It contains the passthrough hack
* It has a distinctive android signature, so you can install it alongside any other XBMC. With further updates, you won't loose your settings.
* It is based on Frodo (12.x)
* Working MPEG2 acceleration
* New GFX
* Handle issue with bottom ghost pixels on some vids
* External players support
* Do not handle POWER button in XBMC (solves issue when using the remote power button)
* Remove HDMI audio option (prevent passthrough issues)
3. Includes many updated apps like
Build Prop editor
Lidroid File Explorer
Es File Manager 3.0.8.0
Cifsmanager (mounts samba shares for XBMC)
Mount Manager(to auto mount shares)
Dolphin Browser 10.2.1
NofrillsCPU (to overclock device)
Tuneinradio v11.1
Videomix v1.7.8(to watch movies)
MxPlayer v1.7.21(to play movies, remember to enable H/W+ mode for better playback)
Youtube v5.3.28
Superuser
Pimpmyrom &
Updated Google apps
Installation
How to install CWM Recovery
Just copy the rom zip file to an SD Card and insert it into your MK808B
1) Install - http://www.mediafire.com/download/4s...t.arctools.apk
2) On the first screen select RK3066 Recovery from the drop down list, download and install it.
3) Select Reboot to recovery from the second tab of the app.
3) In CWM Recovery - Install zip from SD Card -> choose zip from external SD Card -> specify the firmware file, click YES.
After the installation, reboot.
Post Installation
Remember to change animations to 0.5s in developer settings, enable GPU for 2D rendering and disable HW overlay.
Also run Pimpmyrom for some extra usefull network & speed tweaks.
There is also an enable/disable Vsync setting in Pimpmyrom, but don't know if it works.
Download link
For MK808 devices
Just replace the kernel in the zip file with an overclocked MK808, Android 4.1, 720p 3.0.8 kernel from here - http://www.multiupload.nl/L2LWQ0N3GC
Remember to rename the kernel to kernel.img before replacing it in the rom's zip file.
PS: Kernels with GPU > 400mhz don't work properly and will actually make your device slower.
XBMC
The latest nightly versions play video very slow +-8 fps on libstagefright as well as mediacodec and some videos just freeze. Install the latest nightly version alongside it and see for yourself.
This XBMC version actually play videos better than the Feb 19 XBMC build that had some of the best video playback. 1080p Videos that had a lot of dropped frames on the Feb 19 build now play with very little frame drop.
Thanks to user digitop on 4pda for creating the original rom which this is based on.
