How Do I Fit HDMI to mini-HDMI Adapter Into HDMI Port?
    Good day people. I have 1.4 HDMI to HDMI cable that I want to use with PIPO M9 but I had to purchase HDMI female to mini-HDMI male adapter to do it:
    The problem is that female HDMI to male mini-HDMI does not stay in tablet's HDMI port and is loose:
    What can I do here? If I decide to remove some material that covers metal contact, how should I do it? Filing? Cutting? I don't want to mess it up and prefer accurate and clean work.
    Thanks.
    The best thing to use is a razor box knife. Just do a small cut at a time. Test fit it after each cut until you get it to stay in.
      It may be a worn or poor quality adaptor. I have a mini-HDMI to HDMI cable and that fits snuggly in the tablet port.
      Sent from my Pipo M6Pro running RileyRom 1.5.1
        Measure?
        Maybe I should measure from point of recessed HDMI port to the surface of tablet's plastic? That's how I would know hwo much to cut off.
          Avoid surgery on your tablet, I don't think it's the problem. Get a new cable.
            No surgery on tablet. I wanted to measure inside of HDMI port the distance between surface of table until HDMI contact plate to see how much I should cut off from mini-HDMI adapter.
              Not to throw you off but my HDMI cable is exactly .25 inches at the plug and fits snuggly in the HDMI port.
              Cheers!
                Cheers!
                Mine is .23622 inches.
                  Success!
                  Did exactly what I have planned and everything works now. Thanks for your help too.
