nx007hd8g strange mouse cursor issue
I have a nx007hd8g rooted and I bought a otg 4 port hub for it it works great with keyboards and flash drives, etc but when I plug my mouse in, the cursor is the boot image. I have done a factory reset, cleared the cache and memory. Still have the same problem. So wtf???Tags: None
Originally posted by tylerhtc View PostI have a nx007hd8g rooted and I bought a otg 4 port hub for it it works great with keyboards and flash drives, etc but when I plug my mouse in, the cursor is the boot image. I have done a factory reset, cleared the cache and memory. Still have the same problem. So wtf???
I don't remember which version of busybox contains the bug.
Uninstall busybox, check for the issue, upgrade it and check again... if it occurs on the newest version, you may have to manually install a previous version...
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostThis issue has come up before. It is caused by a bug in busybox.
ShaunMT
Re: nx007hd8g strange mouse cursor issue
Originally posted by tylerhtc View PostFunny thing is I installed it and then uninstalled before I knew about the mouse cursor issue and haven't reinstalled since I have reset my tab either. Are there any apps that install busy box as part of their installation?
Sent from my SPH-L710 using TapatalkFreaktab Rom Developer
Originally posted by shaunmt View PostDid you use the installer app to uninstall the upgraded system binaries or did you just uninstall the app?
Originally posted by tylerhtc View PostBefore I just uninstalled the installer but just earlier I installed various versions and uninstalled with the installer and then uninstalled the installer...still no good
There are currently 2300 users online. 0 members and 2300 guests.
