sumvision 297
    Re: sumvision 297
    Glad you got it sorted
    Sent from my GT-I9100 using Tapatalk 2
      [QUOTE=gooner151Glad you got it sorted
      Sent from my GT-I9100 using Tapatalk 2[/QUOTE]
      how did you get catapult king to work ive still got the same problem?
        Originally posted by spawnofdonny View Post
        It works on my sumvision 2 9.7
        have you tried run the the app in normal mode are tablet has hd mode and normal mode
        settings>display>display mode
        I would not flash pipo m6 firmware unless you know what you are doing
        how did get the game to work? ive installed riley 1.6rom and i have same issues?
          I just installed it and worked fine with no issues on my tablet!
          have you contacted the app developer for tech support
          have you tried changing the governors and I0 scheduler (search google to find out more) or try using greenfly to hibernate other apps that may be slowing it down other that i not got a clue
            [Qh=spawnofdongame33573]I just installed it and worked fine with no issues on my tablet!
            have you tried changing the governors and I0 scheduler (search google to find out more) or try using greenfly to hibernate other apps that may be slowing it down other that i not got a clue[/QUOTE]
            I take it you have got the same tablet sum vision 297?
            I have tried governors setting'im not how they work.
            basically the game comes on but the touch screen controls don't respond.
              basically the game comes on but the touch screen controls don't respond.[/QUOTE]
              Yes I have the sumvision 2 9.7 tablet and the game works for me
              HAVE YOU TRY CONTRACTING THE APP DEVELOPERS!!!!!!
                I haQUOTROM are you onpawnofdonny;133703]I take it you have got the same tablet sum vision 297?
                HAVE YOU TRY CONTRACTING THE APP DEVELOPERS!!!!!![/QUOTE]
                what rom are you on?
                i havnt tried governor settings,not sure how that works.not contacted app develop?
                  i havnt tried governor settings,not sure how that works.not contacted app develop?[/QUOTE]
                  Contact them and tell them your problems you have you will find this on Google play store then use Google and see if any one els has problem with the game and see if they have a solution I can not help you with this game because it works fine for me
                    Contact them and tell them your problems you have you will find this on Google play store then use Google and see if any one els has problem with the game and see if they have a solution I can not help you with this game because it works fine for me[/QUOTE]
                    thanks i will contact developer.just seems weird that we have same setup and it works for you.
