I would like to know of its worth me flashing the riley rom, would it make a huge difference or stick with stock version so i get OTA future updates.
sumvision 297
sumvision 297
I have recently purchased sumvision 297 from ebuyer. I believe this tablet is the same as pipo m6. first impressions are very good but when compared with another smaller dual core tablet, it seems as not as fast, browsing and general use is slower but the screen is great. I tried Catapult king last night and although it loaded up fine, the game does not recognize the screen touches so i could not play it, standard resolution is the same.
I would like to know of its worth me flashing the riley rom, would it make a huge difference or stick with stock version so i get OTA future updates.Tags: None
Originally posted by jaykay View PostI have recently purchased sumvision 297 from ebuyer. I believe this tablet is the same as pipo m6. first impressions are very good but when compared with another smaller dual core tablet, it seems as not as fast, browsing and general use is slower but the screen is great. I tried Catapult king last night and although it loaded up fine, the game does not recognize the screen touches so i could not play it, standard resolution is the same.
you could also try and use the pipo m6 pro riley rom i can confirm the rom works but flash at your own risk it will void your warranty
sumvision updates are very rare
Originally posted by spawnofdonny View Postif you are rooted you could try xposed installer and use the app setting module to change the dpi off the game
Originally posted by jaykay View Postwill the rom work on my sumvision tablet?
have you tried run the the app in normal mode are tablet has hd mode and normal mode
settings>display>display mode
I would not flash pipo m6 firmware unless you know what you are doing
Originally posted by jaykay View Postyes i have tried it on both modes.what version of rom are you running and do you find it better than stock?
Re: sumvision 297
I have same tablet but before I flashed rileyrom (which work fine btw) I rooted and installed clockworkmod and backed up original sumvision setup. Then stored this away from the tablet for safe keeping just in case.
So far running rileyrom 1.60 and all is good will probably make the jump to kit kat v1.70 when I've got time.
Sent from my GT-I9100 using Tapatalk 2
Originally posted by gooner1511 View PostI have same tablet but before I flashed rileyrom (which work fine btw) I rooted and installed clockworkmod and backed up original sumvision setup. Then stored this away from the tablet for safe keeping just in case.
There are currently 4581 users online. 1 members and 4580 guests.
