** ROM ** Polaroid AS10 ** ROOTED + TWRP**
Originally posted by guessyet View Post
Originally posted by bigronnich01 View Postdidnt see one on the board i was using phoenix suite 1.0.4 but im not sure if im setup right after all I have been reading to flash they say the tablets has to be powered off and in usb storage mode I can not seem to get the tablet to that point i have done a hand full of rooting and flashing but this one has me stumped
With the tablet completely turned off.... unplug the usb cable from the tablet.. press and hold the volume down button... with the volume down button pressed - plug the usb cable into the tablet.. this will bring the tablet up into flash mode...
Originally posted by guessyet View PostWith the tablet completely turned off.... unplug the usb cable from the tablet.. press and hold the volume down button... with the volume down button pressed - plug the usb cable into the tablet.. this will bring the tablet up into flash mode...
Originally posted by bigronnich01 View Postok going to give that a try (fingers crossed) get back to you in a bit thanks
Originally posted by bigronnich01 View PostI just cannot get this tablet in flash mode I tried hg the vol down and connecting usb cable then i tried holding vol up and connecting usb cable and still nothing i am confused to what im doing wrong any other helpful tips ill try them all :-)
you should have been able to get into flash mode... the screen will not come on in this mode.. there will be no signs of the tablet actually being on... the only thing that will let you know it is in FEL mode is a device will show up in the device manager or with phoenix suite running with a rom selected .. phoenix suite will ask if you want to do a format upgrade or normal upgrade...
Originally posted by guessyet View Postyou should have been able to get into flash mode... the screen will not come on in this mode.. there will be no signs of the tablet actually being on... the only thing that will let you know it is in FEL mode is a device will show up in the device manager or with phoenix suite running with a rom selected .. phoenix suite will ask if you want to do a format upgrade or normal upgrade...
model-a/s10
soc chip super dual core a20
android 4.2.2
kernel 1.0.0
build number as10-20130827
when running phoenixsuite it still says no device
guessyet.
Originally posted by bigronnich01 View Posti am still having a problem flashing recovery i just want to run the teblet info by you to make sure this procedure will work
model-a/s10
android 4.2.2
kernel 1.0.0
Originally posted by bigronnich01 View PostGuessyet. Any verdict on new polaroid firmware?
they are pretty much the same as the old ones.. except for a different bootloader image with a big S in it.. same kernel with 4.2.2.. it does seem as if southern telco cleaned up their code when compiling it.. but there is no major enhancements that i have found..
I have been torn on time lately because as Electrik stated.. we are working on bringing kitkat to the polaroid devices.. So i have been spending most of my time on doing so.. lol.. its not a quick process .. however, i think most would rather have cm11 than the latest polaroid rom running 4.2.2 with break-fix additions..
I do have cm11(very much a pre-release) built for the devices and I am working on polishing the kernel.. I have been editing the kernel sources to include the latest sources for the hardware (such as the latest mali sources)..
Hopefully, cm11 will be complete for these devices soon..
Originally posted by guessyet View Postthey are pretty much the same as the old ones.. except for a different bootloader image with a big S in it.. same kernel with 4.2.2.. it does seem as if southern telco cleaned up their code when compiling it.. but there is no major enhancements that i have found..
There are currently 2916 users online. 0 members and 2916 guests.
