That's my experience, too. In the first days, i had no problem, but as more apps were added, the system was getting slower & slower. These days i am trying to optimize the situation with 'greenify' app.
Pipo S1 Pro RileyROM 1.1
Re: Pipo S1 Pro RileyROM 1.1
Originally posted by chillout23 View PostI flashed new rom. better and much faster. And much better battery timebut do not want to write about it here on Riley's topic
[email protected]
It's OK to post a link to the ROM. It won't hurt my feelings....it's all about making the tablet better.Randy
Ok then RileyI am glad to hear that
So...here is ROM I flashed: http://www.rockchipfirmware.com/node/246
We will be glad to give it a try and expose your opinion comparing it.
Ok...thanks for info
If there will be problems with this ROM, I will try Kasty's ROM then: http://www.arctablet.com/blog/forum/...ware-20131213/
Kasty got option to CWM install: http://www.arctablet.com/blog/forum/...k3188-devices/
Hm...if problem exist after few days of usage with current ROM then is HW problem I think :/
I will ask my daughter in few days if she is satisfied or it's the same as beforeand will take a look about it and will post here
Please understand the nature of custom ROMs.
The common thing among all of these ROMs is that they are all based on the same stock firmware. The problem does not arise from anything I or the other developers have done.
Aside from rooting, debloating and adding some other custom features...it is basically the same as the stock firmware.
Much of what you are describing happens in the kernel...which we don't have the source code to recreate.
The only solution would have to come from a factory firmware update.Randy
Originally posted by rrileypm View PostPlease understand the nature of custom ROMs.
In anyway, we have to thank you Riley for your effort!
Pipo seems to respond quite well to reports of bugs in their firmware. If enough users report the same problem, they may provide an update with a fix.Randy
Randy
There are currently 1968 users online. 0 members and 1968 guests.
