Beyond XBMC
I cant seem to get audio to work on the XBMC HDMI setting, all I get is white noise.
I am using Finless 1.8 and aboveXBMC app.
I have tried all the sound output options through android settings and I get white noise through HDMI out on XBMC. I can only get audio when XBMC is set to Analogue output 5.1 (is the Analogue setting actually outputting 5.1 or just stereo?)
Anyways if anyone else has good the HDMI passthrough to work properly please tell me what Im doing wrong.
Originally posted by Flumpster View PostIf you want only 720p then flash a 720p kernel for your rom. This will speed things up slightly all around.
I am running wasserROM and it has a setting 1080p/720p and I am using the lower but there is not option in Beyond XBMC. With the official XBMC or with the Ugoos provided XBMC there was. Also, when I try to calibrate it shows that it is running 1080p so my TV must do the down-scaling. I would not bother but the video becomes jerky when there is a GUI on top of the video, e.g. when you press mouse when the video is playing and it displays the controls on top of the video.
Thanks,
Ari
Thanks,
Ari
On the screen that appears what does it say the screen resolution is set to?To Infinity and Beyond.... XBMC
Originally posted by Flumpster View PostCome over to system on the far right and then come down and select system info.
-Ari
Originally posted by lifeisfun View PostIn the xbmc system settings
Originally posted by arinium View PostI am running wasserROM and it has a setting 1080p/720p and I am using the lower but there is not option in Beyond XBMC. With the official XBMC or with the Ugoos provided XBMC there was.
Originally posted by arinium View PostYes, in the official build and in the Ugoos provided XBMC there is a setting in System -> System -> Video output. But with Beyond XBMC there are only two options: "Vertical blank sync" and "Video calibration".
You said in an earlier post that your TV didn't support full HD but it must.
Try changing the kernel to 720p mode and trying again.To Infinity and Beyond.... XBMC
There are currently 1719 users online. 4 members and 1715 guests.
