Does this mean I have to send it away for repair? Will a software battery calibration help?
Pipo M8HD RileyROM 1.4 KitKat
Because I get this in 4.4, but everything is good in 4.2
If you have this in 4.4, just wait for a new ROM version from Pipo
The customer said it would sometimes go flat after 1 hour. When I had this tablet, I was getting up to 14 hours of video playback.
The thing is, I CANNOT use 4.2 as I get the sleep of death all the time and have to reset.
I think it needs to be repaired. And I bought from dealsprime and am unsure of their service.
This is not a lack of battery voltage problem as it shows 4.2V and this is idle with low brightness so the voltage isn't dipping. It must be the regulator then, not the battery itself.
Originally posted by nztdm View PostNope. Its fine in 4.2. I sold this tablet to a customer (with 4.2) and gave them a horrible experience. I'm trying to fix it.
Fully charge the tablet. Re-flash it to stock android 4.2.2 f/w to be sure that it is installed now fine.
Root tablet and then recalibrate battery by "Battery Calibration" application following instruction shown on the screen.
Remove root in SuperSU app.
Check tablet's behavior until it is discharged. Fully charge again and do video playback for 2 hours.
If steps from above didn't help, re-flash to stock f/w again to eliminate all rooting tracesand then bring to service.
upd: This tablet has 2 batteries inside with a separated regulator on motherboard. No regulators are built in the batteries.Last edited by KEvgeniy; 17 January 2014, 10:31. Reason: upd: This tablet has 2 batteries inside with a separated regulator on motherboard. No regulators are built in the batteries.
Hi to everyone!
Still no news about M8HD and KitKat?
It is really a pity, since the tablet itself is really good... I say this not only because I actually have one, but recently I have used some other tabs, even of more famous brands (and much more expensive), but still the M8HD with some customization and optimization really can hold its place and look and feel good, not cheap in many ways....
I've been watching every day...still nothing new from China.Randy
How to enable GPS? in te
The ROM Pipo M8HD RileyROM 1.4 KitKat runs very smooth but my question is how to activate the GPS, I find the option to activate
How to enable GPS?
The ROM Pipo M8HD RileyROM 1.4 KitKat runs very smooth but my question is how to activate the GPS, I find the option to activate.
Thanks for your work.
Originally posted by matrix666 View PostThe ROM Pipo M8HD RileyROM 1.4 KitKat runs very smooth but my question is how to activate the GPS, I find the option to activate.
There are currently 7508 users online. 1 members and 7507 guests.
