Has this happened to anyone else or is there a way I could do some sort of rollback or restore?
Screen Flashing after MK908ii Finless ROM 1.5a
I have installed the ROM buy after the box restarted the screen is now constantly flickering between a blank screen and the screen I should expect to see? I flashed the ROM again but to the same issue?
Has this happened to anyone else or is there a way I could do some sort of rollback or restore?Tags: None
Guest
Originally posted by jonwalters23 View PostI have installed the ROM buy after the box restarted the screen is now constantly flickering between a blank screen and the screen I should expect to see? I flashed the ROM again but to the same issue?
Guest
Well, on my MK908ii, I have just test this. I installed Finless 1.5a with the 720vsync kernel and the boot720 boot option. I had screen flickering, but I changed in settings, 'HDMI mode' to 720p-60 with no flickering. I will try with the same variation, but the 1080vsync and the boot1080 to see if that will still work.
Guest
So far, even with both the 1080p for the kernel and boot, I have to change the HDMI mode to 720-60 to stop the flickering.
Guest
So, I think the only valid solution that I can find for this - for any variation of kernel/boot install that you choose - you will have to change the HDMI Mode to '1080x720p-60' in the settings menu (Settings->Screen->HDMI Mode) of the device. Unless someone else could lend a better solution, this is the only thing I can come up with and this was simply through trial and error. It's not a significant issue in perspective, unless you have an amazingly HUGE television set, than the 1080p-720p shouldn't really play much of an issue.
Hope this helps.
Originally posted by KolyaIsAwesome View PostSo, I think the only valid solution that I can find for this - for any variation of kernel/boot install that you choose - you will have to change the HDMI Mode to '1080x720p-60' in the settings menu (Settings->Screen->HDMI Mode) of the device. Unless someone else could lend a better solution, this is the only thing I can come up with and this was simply through trial and error. It's not a significant issue in perspective, unless you have an amazingly HUGE television set, than the 1080p-720p shouldn't really play much of an issue.
Hope this helps.
The good news...the new Rom 4.4.2 of finless, the problem dissapear.
Originally posted by ekanemore View PostI have 3 mk908ii and i put finless 1.5a and hdmi mode to 1080p. 2 of them, the screen flicker every 3 or 4 seconds, the other one is perfect. I use the same cables in all of them.
Guest
Originally posted by KolyaIsAwesome View PostI think the main issue is it's more than just flickering, it's more or less the screen going off and on.
Sorry, i thought the meaning of "flickering" was it...
I will test other things and i inform you if i get something....
I have got the CX-919, but I have the same problem. The strange thing is that with the original stock firmware the CX-919 seemed to work fine, after I tried to flash Finless 1.6b it started to flickering (with black screen every 4-5 seconds), and continued also after I flashed the last stock firmware. Only with a rom called "rescue rom" seems to doesn't show the issue, so I'll test with Neomode and previous releases of Finless and stock, but it's a very strange thing... Does anyone know why?
Originally posted by cluster_danneggiato View PostI have got the CX-919, but I have the same problem. The strange thing is that with the original stock firmware the CX-919 seemed to work fine, after I tried to flash Finless 1.6b it started to flickering (with black screen every 4-5 seconds), and continued also after I flashed the last stock firmware. Only with a rom called "rescue rom" seems to doesn't show the issue, so I'll test with Neomode and previous releases of Finless and stock, but it's a very strange thing... Does anyone know why?
Originally posted by cluster_danneggiato View PostYes, I think so, but I would understand why with many well-known roms the issue persists, while with the rescue rom no... I MUST understand...
If it is flashing in CWM then it is not the OS (ROM) but it could be the kernel. The kernel is used in CWM too.
Possibly some hardware change over time now needs some timing change in the kernel? I do not know as I do not have the issue. I would try other kernels. Even if wifi doesn't work on a different kernel, you can see if flashing continues.
It would have been nice if on one of those 2 stick you have, if you could have dumped the kernel image. We could use that to test. Did it flash on the stock ROM? If not, we need that kernel to take a look.
Originally posted by Finless View PostIf it is flashing in CWM then it is not the OS (ROM) but it could be the kernel. The kernel is used in CWM too.
There are currently 1954 users online. 0 members and 1954 guests.
