Arnova 9G2 ICS 4.0.3 seems to be available on the market
    Originally posted by chrila View Post
    1. I shut down my tablet
    2. I push button "menu" and let down
    3. I put a paperclip into "reset" and let down, my computer says "unrecognized usb device"
    4. I relax reset with "menu" down again and unfortunately, the arnova logo appears, so my tablet isn't in download mode...i block at this point, i've tried a lot of combination of button, with many space between relax, but nothing works...
    i try "kasty rom 1.11" and it's a file named "update.img", but it's nott ics...too bad
    Yeah, that sequence is the one working for many people here in the forum, apparently not for you...
    Only one question on point (3):
    - when you press the reset button do you use a "long" or a "short" reset?
    I do not have the tablet anymore, but I remember "short reset" was the good one
    If you want to try ICS, I believe "download mode" is the only solution.
    With kasty rom you can get "google play" and all the google apps, which is already better than the stock rom at least :-)
      long reset or short reset
      i tried everything short rset , long reset, if i relax paperclip the tablet restart !!
      is there different model of arnova 9 g2 ??
        Hopefully ics for 10 g2
        Cant wait to see ICS for 10 g2 since its work on 9
