Next7P12-8G (2013 models) with wifi issues serial research thread
Build.prop
I have two 7p12-8g with july build dates. One has stock untouched rom but rooted and the other is rooted and I flashed the Stock rom from this site and im having wifi issues. I've compared the build.props side by side and there are a few things missing. So i added the ones that were missing and it didnt make a difference as far as wifi goes. There are 14 channels under the wifi. I dont enough experience to know what is nessesary.
I did a rom dump on the good one and sent it to Shaunmt. He said that he was working it two days ago. let me know if I can help in any way.
Originally posted by aldrich_39 View PostI have two 7p12-8g with july build dates. One has stock untouched rom but rooted and the other is rooted and I flashed the Stock rom from this site and im having wifi issues. I've compared the build.props side by side and there are a few things missing. So i added the ones that were missing and it didnt make a difference as far as wifi goes. There are 14 channels under the wifi. I dont enough experience to know what is nessesary.
Use a build prop editor from the play store to check the date in the build.prop. Some tablets have a ROM with an earlier build date that the tablet's manufacture date. Makes sense if the ROM hasn't been updated but they are still making tablets.
Have you signed up for testing in the volunteer thread?
ShaunMTFreaktab Rom Developer
Originally posted by aldrich_39 View PostThe build date is Tue Jun 18 14:31:16 cst2013...
I can sign up but i looked and there was already some other people with the same build date and version as mine. Didnt think there should be two of the same versions.
Feel free to signup if willing. I think you were the only person who successfully provided a good ROM dump!
Just because they signed up, doesn't mean I'll select them for testing... but at least some of them stopped bugging me for test files. A lot of them didn't even provide all the info I asked for...
Originally posted by thebiggboss180 View Postfull build prob ..upload it if u can
Originally posted by thebiggboss180 View Postman
my internet is sucks... and downloading 300~~200mb for 10 kb file is madness
Code:# begin build properties # autogenerated by buildinfo.sh ro.build.id=IMM76I ro.build.display.id=IMM76I.v005 ro.build.version.incremental=eng.root.20121023.123421 ro.build.version.sdk=15 ro.build.version.codename=REL ro.build.version.release=4.0.4 ro.build.date=Tue Oct 23 12:37:47 CST 2012 ro.build.date.utc=1350967067 ro.build.type=user ro.build.user=root ro.build.host=midcs-desktop ro.build.tags=release-keys ro.product.board=NXM727MC_WM ro.product.cpu.abi=armeabi-v7a ro.product.model=Next7P12-8G ro.product.brand=Nextbook ro.product.name=M727MC ro.product.device=M727MC ro.product.cpu.abi2=armeabi ro.product.manufacturer=YIFANG ro.wifi.channels=14 ro.board.platform=meson3 # ro.build.product is obsolete; use ro.product.device ro.build.product=NXM727MC_WM # Do not try to parse ro.build.description or .fingerprint ro.build.description=NXM727MC_WM-user 4.0.4 IMM76I eng.root.20121023.123421 release-keys ro.build.fingerprint=Nextbook/M727MC/M727MC:4.0.4/IMM76I/v005:user/release-keys ro.build.characteristics=tablet # end build properties # system.prop for M1 reference board # This overrides settings in the products/generic/system.prop file # #rild.libpath=/system/lib/libreference-ril.so #rild.libargs=-d /dev/ttyS0 ro.sf.lcd_density=120 keyguard.no_require_sim=1 #set keyguard.enable=false to disable keyguard keyguard.enable=true ro.statusbar.widget=true ro.statusbar.button=true ro.statusbar.yearmonthdayweek=true #wifi.interface=ra0 # Time between scans in seconds. Keep it high to minimize battery drain. # This only affects the case in which there are remembered access points, # but none are in range. #wifi.supplicant_scan_interval = 60 #alsa.mixer.playback.master=DAC2 Analog #alsa.mixer.capture.master=Analog #configure the Dalvik heap for a standard tablet device. #frameworks/base/build/tablet-dalvik-heap.mk dalvik.vm.heapstartsize=5m dalvik.vm.heapgrowthlimit=40m dalvik.vm.heapsize=256m hwui.render_dirty_regions=false # Disable un-supported Android feature hw.nopm=false hw.nobattery=false hw.nophone=false hw.istablet=true hw.novibrate=true hw.has.accessibility.accel=false hw.cameras=1 hw.hasethernet=false #hw.hasdata=true ro.platform.has.touch=true hw.nodatausage=true # Wi-Fi sleep policy ro.platform.has.sleeppolicy=false #set to 0 temporarily so touch works without other changes ro.sf.hwrotation=270 #0~7 You are required to get the correct install direction according the sensor placement on target board ro.sf.gsensorposition=4 ro.sf.ecompassposition=4 allow_all_orientations=1 # Use OSD2 mouse patch ro.ui.cursor=osd2 # Enable 32-bit OSD sys.fb.bits=32 # Disable GPS gps.enable=false # Enable player buildin media.amsuperplayer.enable=true media.amplayer.enable-acodecs=asf,wav,aac,m4a,ape,flac,alac media.amplayer.enable=true media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER media.amsuperplayer.defplayer=PV_PLAYER media.amplayer.thumbnail=true # Status bar customization ro.statusbar.widget.power=true ro.statusbar.yearmonthdayweek=true # HDMI ro.hdmi480p.enable=true rw.fb.need2xscale=ok media.amplayer.osd2xenable=true #camera DCIM dir. 0:sd only; 1:nand only; 2,sd first ro.camera.dcim=1 # Disable preload-class ro.amlogic.no.preloadclass=0 # App optimization ro.app.optimization=true #Dual display ro.vout.dualdisplay2=true #For 800x480 UI ro.platform.UI.800x480=true #For Erase internal SD card hw.erase.internalSdcard=true #audio effect ro.audioEffectEnabled=true #Encrypt tablet #ro.platform.has.security=false #YF prop ro.yifang.devicename=Next7P12-8G ro.yifang.lcd=1 ro.yifang.hotpoint=0 ro.yifang.hdmi=false ro.yifang.weather.city=New York ro.yifang.weather.isf=1 ro.yifang.ota.enable=1 ro.fontScale=1.15 virtualsd.enable=true ro.keyguard.orientation=landscape #hdmi settings ro.hdmi.has.settings=false #used forward seek for libplayer media.libplayer.seek.fwdsearch=1 #enable address bar cover issue fixing ro.flashplayer.surfacehack=1 #google client prop ro.com.google.clientidbase=android-anydata #enable widevine media.amplayer.widevineenable=true #used to set default surface size, set 1 when hwrotation is 270; # # ADDITIONAL_BUILD_PROPERTIES # ro.opengles.version=131072 ro.config.notification_sound=OnTheHunt.ogg ro.config.alarm_alert=Alarm_Classic.ogg drm.service.enabled=true ro.setupwizard.mode=DISABLED ro.com.google.gmsversion=4.0_r4 net.bt.name=Android dalvik.vm.stack-trace-file=/data/anr/traces.txt ro.hardware.version=1.0.0.0 ro.vendor.name=YFMID
There are currently 3630 users online. 0 members and 3630 guests.
