MK808b - Please help all i see is 2 PENGUINS
    There are many versions of the MK808B with AP6210 wireless chipset. Is it the EXACT same hardware as in post#6?
    If not, post a picture of the inside of your stick.
      The same.
      Inviato dal mio Nexus 7 utilizzando Tapatalk
        Originally posted by gigi74 View Post
        The same.
        Actually, if it is the same and you really did follow the instructions properly... you wouldn't see the two penguins. So something is wrong... I'd suspect you got the wrong ROM for your hardware since that is probably the most common error.
          can i have a right link of ROM?
            Right now, it looks as if there are two possible things that could be wrong... we can only go by what info you give ( which has not been a lot ) but the following are the two areas in question.
            You will need to get good pictures of both sides of the board in yours and post them. That way someone else can compare your pic's with the others to verify it is the same as this one or a different one. Without pictures, there is no way for someone else to guess what one you do or do not have.
            If it is the same... then it would point at the problem being that you didn't follow the instructions properly... which also would need help.
              When i come to home, make photo and post...
              Inviato dal mio GT-I9300 utilizzando Tapatalk
                R: MK808b - Please help all i see is 2 PENGUINS
                  The pic's you posted are like you said... they are of the same device. That leaves the method you used to install as the part in question...
                  The link to the ROM and the instructions that hotmonster used is here http://www.freaktab.com/showthread.p...l=1#post144781
                  I suspect if you have issues following those instructions... it would be best to post in that thread for additional help since the others that it worked for may monitor it...
                    Working ROM will be soon
                    Good news for owners of green pcb 1 antena mk808b android 4.2.2 (rk30sdk-eng 4.2.2 JDQ39 eng.zs.20131219.191736 test-keys) RK3066_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130308 ap6210 chip onboard owners!
                    You can found out more here http://www.freaktab.com/showthread.p...l=1#post163577
