Tested wih many RK3066 differents rom
MK808b - Please help all i see is 2 PENGUINS
MK808B_AP6210_root_20131023.zip http://pan.baidu.com/s/1f3MDC?qq-pf-to=pcqq.c2cnow
Originally posted by malfrat View Post?
My wifi chip is rk903 then if i succes in flash i will lose wifi & BT.
Originally posted by hothmonster View PostMalfrat can you elaborate on how you managed to fix it?
I have definitely tried different types of USB leads and PSUs. No luck.
This latest flash with the above zero devices seems to be doing more. When it first boots up i get a recovery mode message, then formatting device, cache, and SD card messages. Then it either keep looping round through zero devices logo or and android logo.... At least its something different!
if you have a good hdmi cable (not the china supplied one=gabage) and it not solve the issue try this:
or take a look there :
or
from : http://www.freaktab.com/showthread.p...l=1#post102179
or
read all this :
also google and baidu is our friend
hope it help and also keep you busyno sincerly wish it work for you
Originally posted by hothmonster View PostThis latest flash with the above zero devices seems to be doing more.
I found this on Android-Hilfe, going by the filename it is older than malfrat's, but still an option:
Here is ORIGINAL firmware (rooted) for MK808B with AP6120: https://www.dropbox.com/s/msl7aq0i01...30828_V1.0.img
You said you tried MK802III ROM and Zero devices, but never mentioned trying the one I suggested: http://vondroid.com/resources/mk808b...i-chipset.358/
Originally posted by gigi74 View PostI have same problems... Tried many roms but i van see only penguins, googletv logo or rikomagic logo.
Inviato dal mio Nexus 7 utilizzando Tapatalk
Originally posted by gigi74 View PostI flash with toolkit not by recovery and plugged only USB cable on OTG port. It's the same?
The instructions on how to flash Finless ROM's that he has made are included with them... it is the readme first.txt file....
There are currently 1629 users online. 0 members and 1629 guests.
