I hope you can help me. I have recently purchased an MK808b from deep dark China via ****. I have cracked it open and it definitely looks like the original version. From what i see from the first thread on identifying the clones the other versions have multiple cables within it, whilst mine only has the one. There are no distinguishing writings or markings to identify it differently.
So...
I followed the ROM -> MK808B JB 4.2.2 "Official" - Finless 2.1 ROM (275 megs)
instructions by Finless. Thanks by the way.
I got the drivers installed on my laptop, (chose the x64 folder rather than x86 because of my win7 64 bit machine)
To boot into flash mode it only works by using the alternative method, using the regular flash tool it just comes up with error messages each time.
The flash went through fine, i didnt change any of the parameters and kept them as default as per the instructions, the device restarted as planned but on the TV all i get is two of the linux penguins, and it will go no further. I have searched the forum for 'penguins' but nothing comes up.
HELP!
Now of course i cant click the 'connect to PC' in the android menu, so how can i get it into flash mode?
What did i do wrong?
Whats my next step? Should I try a different ROM?
Thanks in advance.
