1. Restoring using Dessa's ROM dump - works fine, U4K restored
2. Making 1920x1080 desktop on restored U4k - works fine.
3. Amending Kimdescent ROM to work on U4K - fails - suspect kernel coded for wifi/BT
4. Amending Kimdescent ROM to have U4K boot.img / bootloader / kernel - fails to boot (bricks!)
5. Using U4k sys_config on 4.2.2 builds - no effect
So currently I'm 'stuck' on 4.1.1 but at 1080p. THe stick gets ridiculously hot so I can understand why everyone overclocks.
If you want 1080p the method is to extract the stock script.bin from partition a (nannda), convert to .fex, edit and then reconvert and cat back to partition a.
If you're interested and want a shortcut I can upload a 1080 script.bin but on the old 4.1.1 builds this has an antutu of 10,800 which is shocking!!
