1.)
Why do you use the android-kernel as recovery /at "recovery-partition"?
Because if you are able to create a linux-partition (as final), why don't you create a new partition like "android-kernel" (I don't know if it will work witch RKbatch, because I only user RKTool for separate partitions)?
Is it because of only patching the boot.img instead of recompiling?
If you manage it in the linux-kernel, it only have to fixed there?
2.)
If I only want to use SD or USB is it really needing to have a linux-partition at NAND?
