Thanks for your info brother but I asked that I want to use linuxium rfs at nand instead of picuntu rfs(all files from picuntu and replace system.img with linuxium ubuntu.img). I doubt that may be some difference in parameter file(sizes are defferent of both rfs) which may cause non booting.
Linuxium's Bootloader software to dualboot Android and Linux
Originally posted by ani1nonly View PostI doubt that may be some difference in parameter file(sizes are defferent of both rfs) which may cause non booting.
You only replace the system.img?
I don't think (but ofcause not shure) there is a problem with the paramter, because the kernel 'mounts' the MTD partitions depending on the parameter(file), so if you flash the original parameter, boot.img (initramfs) and the kernel.img and only replace the system.img, norrmally it must minimum boot to "character-mode-screen" (initramfs)...
There you can dmesg and mount for a > to file (don't forget to umount) and analyse it at pc...
You also can do e.g. 'ls -al /dev/disk/by-name' or 'ls -al /dev/block' or 'cat /proc/mtd' or 'cat /proc/partitions' etc...RK3288 Devices
- Overview BOX (LINK !)
I don't think that the picuntu boot.img will work with something other then picuntu, because it seams so, it checks if there is a picuntu (but I'm not shure):
init
Code:mount -t ext4 /dev/mtdblock2 /mnt touch /mnt/picuntu_is_on if [ -f /mnt/resize_nand ] ; then umount /mnt grep -q '\<quiet\>' /proc/cmdline || echo "PicUntu is checking root file system ..." e2fsck -y /dev/mtdblock2 grep -q '\<quiet\>' /proc/cmdline || echo "Now resizing root file system ..." resize2fs -f -p /dev/mtdblock2 mount -t ext4 /dev/mtdblock2 /mnt rm /mnt/resize_nand fi # G8 - Check for first boot if [ -f /mnt/first_boot ] ; then grep -q '\<quiet\>' /proc/cmdline || echo "Congratulations, this is the first boot." touch /mnt/etc/picuntu_1stboot.sh chmod 777 /mnt/etc/picuntu_1stboot.sh /mnt/etc/picuntu_1stboot.sh rm /mnt/first_boot fi umount /mnt
RK3288 Devices
Defconfig?
I want to rebuild the kernel to add gasp module, anyone know the defconfig which is used by linuxium (according next info)?
Target : rk3188 (Rikomagic MK802IV equivalent)
Git used (I think?) : https://github.com/linuxium/3188-SRC-AP6210
thk
Originally posted by GoblE View PostI want to rebuild the kernel to add gasp module, anyone know the defconfig which is used by linuxium (according next info)?
thk
Originally posted by linuxium View Postconfig available here: https://drive.google.com/file/d/0B99...nB0QTRoVXp0RUE
I can't get the file ("access denied"), I think it havn't public access :/
Originally posted by ani1nonly View PostThanks for your info brother but I asked that I want to use linuxium rfs at nand instead of picuntu rfs(all files from picuntu and replace system.img with linuxium ubuntu.img). I doubt that may be some difference in parameter file(sizes are defferent of both rfs) which may cause non booting.
You will need Loader, Parameter, Boot, Kernel & RFS (which you already have). Linuxium has developed kernels for particular devices (MK802IV & T428) however if you have a Linux (rockchip 3188) kernel that works for your device you can substitute it in. Either of Linuxium's kernels will boot but may or may not support your network interfaces (Lan/Wi-fi). There are a multitude of Linux kernels scattered around the boards and if you know the network chips of your device it will greatly help you find the right one or compile your own.
Also don't forget to "Erase IDB" before flashing.
REMINDER - THIS PROCESS ERASES EVERYTHING ON YOUR DEVICE!
Originally posted by enrique66_35 View PostThat's what I'm running on a T-r42 and best to scrap Picuntu entirely and flash (use the same flash tool if you wish) with Linuixum's files here.
Thanks brother
I will try all available combinations(I will change all kernels Working for my device one by one while unchanging the other files by linuxium(ubuntu on nand post I.e. loader, parameter, boot, and rfs)). I will tell you the results as soon as possible.
Btw my device is netxeon mk809iii_v1.0_20130606 - cpu rk3188t wifi-ap6210 and i think that it is equivalant to mk802 iv.
Ani1nonly
CX 919 - AP6210 - Boot Menu problem
Hello,
can someone give an 'semi-linux-noob' a hint what i'm doing wrong.
I tried this: (From first Post)
1. Flashed this:
Rikomagic MK802IV (latest model) - https://drive.google.com/file/d/0B99...jVLSHlhQXVnX0k
2. Then i copied this Linux Image with Win32 Disk Imager Tool on SD Card:
Ubuntu (https://docs.google.com/file/d/0B99O...TFZbHg3ZWE3LXc)
Now, i don't have Ubuntu in Boot Menu.
The only System available in Boot Menu is Android, which boots and works just fine.
What am i doing wrong?
Is the 'misc' part of Rikomagic MK802IV not necessary, because there is no such file in the firmware packet.
Would be really nice if someone could give me a step by step guide for my CX-919 Stick.
Or is this not possible with CX919?
And what can i do exactly with this modules:
To add the Linux modules to the Linux RFS simply:
1. Download the relevant modules and unzip the file:
Rikomagic MK802IV (latest model) - https://drive.google.com/file/d/0B99...jFXMmJId2l5TkE
2. As root enter 'cd /lib/modules' and then 'cpio -ivdum < <unzipped_modules_file>'
3. Reboot
Sorry, but i'm really a new linux user.....
Originally posted by Stuckmojo667 View PostAnd what can i do exactly with this modules
E.g. for the AP6210 of your CX-919 (or other filesystems like ntfs).
The kernel loads them automatically if need (but if I understand it correctly normally you have to do 'sudo depmod -a' at terminal after you have copied them).
Manually load: 'sudo insmod {path-kernelobject.ko}'
With 'lsmod' you can check witch ko's are actually running.RK3288 Devices
Language support?
what do I have to do to change the language?
At 'System Settings' -> 'Language Support' the [Install / Remove Languages...] isn't available.
Because of that, I do:
Code:sudo apt-get install language-pack-de sudo apt-get install language-pack-gnome-de
I can't change 'Keyboard Layout' too.
PS:
Ok, don't ask me why and how, but after second or third 'relogin' it is in German and know I understand the + at Keyboard-Windows to add German Keyboard-Layout...
(perhaps because of a parallel active VNC session??? I don't know)RK3288 Devices
UVC
There are some problems with UVC module.
When I connect my camera (Logitech C270 which works fine with an other board [IGEP with a yocto distribution & kernel 2.6.37] ), my dmesg :
Code:[COLOR=#29F914][FONT=Andale Mono][ 265.007268] usb 2-1.2: new full speed USB device number 6 using usb20_host[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 265.115954] usb 2-1.2: not running at top speed; connect to a high speed hub[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 265.222686] usb 2-1.2: New USB device found, idVendor=046d, idProduct=0825[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 265.222705] usb 2-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=2[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 265.222722] usb 2-1.2: SerialNumber: 31D6E0B0[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 265.224268] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0825)[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 265.324808] input: UVC Camera (046d:0825) as /devices/platform/usb20_host/usb2/2-1/2-1.2/2-1.2:1.0/input/input3[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.326090] 6:3:1: cannot set freq 16000 to ep 0x86[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.382855] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7f2a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.382884] uvcvideo: Failed to query (GET_DEF) UVC control 2 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.382941] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7f2a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.382977] uvcvideo: Failed to query (GET_DEF) UVC control 2 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383027] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7f2a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383054] uvcvideo: Failed to query (GET_DEF) UVC control 2 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383096] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7f2a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383119] uvcvideo: Failed to query (GET_DEF) UVC control 2 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383162] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb79ca[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383186] uvcvideo: Failed to query (GET_DEF) UVC control 3 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383226] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb79ca[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383250] uvcvideo: Failed to query (GET_DEF) UVC control 3 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383292] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb79ca[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383316] uvcvideo: Failed to query (GET_DEF) UVC control 3 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383356] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7b6a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383380] uvcvideo: Failed to query (GET_DEF) UVC control 7 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383423] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7b6a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383446] uvcvideo: Failed to query (GET_DEF) UVC control 7 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383486] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7b6a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383511] uvcvideo: Failed to query (GET_DEF) UVC control 7 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383564] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xeb835305[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383588] uvcvideo: Failed to query (GET_DEF) UVC control 11 on unit 2: -1 (exp. 1).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383629] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xeb835305[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383655] uvcvideo: Failed to query (GET_DEF) UVC control 11 on unit 2: -1 (exp. 1).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383695] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xeb835305[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383719] uvcvideo: Failed to query (GET_DEF) UVC control 11 on unit 2: -1 (exp. 1).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383767] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xec19104a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383793] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383833] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xec19104a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383857] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383898] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xec19104a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383924] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383968] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xeb835785[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.383992] uvcvideo: Failed to query (GET_DEF) UVC control 5 on unit 2: -1 (exp. 1).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384034] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xeb835785[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384060] uvcvideo: Failed to query (GET_DEF) UVC control 5 on unit 2: -1 (exp. 1).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384100] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xeb835785[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384123] uvcvideo: Failed to query (GET_DEF) UVC control 5 on unit 2: -1 (exp. 1).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384166] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7f8a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384191] uvcvideo: Failed to query (GET_DEF) UVC control 10 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384231] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7f8a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384255] uvcvideo: Failed to query (GET_DEF) UVC control 10 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384297] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7f8a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384321] uvcvideo: Failed to query (GET_DEF) UVC control 10 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384361] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7aea[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384385] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384426] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7aea[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384450] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384491] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xebeb7aea[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384515] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384557] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xec16980a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384580] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384620] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xec16980a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384644] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -1 (exp. 2).[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384686] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xec16980a[/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono][ 266.384710] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -1 (exp. 2). [/FONT][/COLOR]
Code:[COLOR=#29F914][FONT=Andale Mono]ioctl querycontrol error 5 [/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono]ioctl querycontrol error 5 [/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono]ioctl querycontrol error 5 [/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono]ioctl querycontrol error 5 [/FONT][/COLOR] [COLOR=#29F914][FONT=Andale Mono]Unable to dequeue buffer (22). [/FONT][/COLOR]
There are currently 1625 users online. 1 members and 1624 guests.
