Linuxium: Huge thanks and good work on this. Have you considered making it an open-source project on github or something? That way people could perhaps improve on it and make it work on other devices.
Linuxium's Bootloader software to dualboot Android and Linux
Re: Linuxium's Bootloader software to dualboot Android and Linux
Dear linuxium
I m little bit confused in applying your tutorial relating to write linux rfs to sd card. When i checked the storage info after flashing your update.img there is only 4gb used out of 8gb(2gb root file system of android and 2gb showing as internal sdcard.). Where is remaining 4 gb of space. Please clearify as there is not a sufficient storage to hold linux-rfs.img(2.5gb approx.)
And i m unable to write rfs to usbstick by windiskimager because after creating ext4 partition using mini partition tool win7 is not recognizing usbstick and asking to format it. And windiskimager also not showing any attached usb storage.
Please help me.
Or best solution is that can you provide update.img having ubuntu-rfs.img(just like your previous update.img having android system.img inside it. So peoples like me can install and enjoy your hard work.
Ani1nonly
Sent from my MIUI By Java using Tapatalk 2
Linuxium thanks for your fantastic work.
I want say if is possibile flash linux image directly to the nand without use dualboot such as Picuntu distro.
I want to use my Minix X7 as a mini pc linux, and I don't want to have Android installed.
With this image "Ubuntu with Mali (https://drive.google.com/file/d/0B99...1hQQ2VybldVYU0)" hardware acceleration is enabled?
Thanks again.Last edited by datrix; 29 March 2014, 10:52.
Custom kernel
I have some trouble to use my own kernel (for Linux, not Android) :/
I use the Linuxium's kernel, with the Linuxium's .config (I have change 2,3 configurations).
I generate the kernel.img like that :
Code:$ make -j8 zImage $ ../rkutils/rkcrc -k arch/arm/boot/zImage kernel.img
Now I flash my kernel with RKAndroidTool :
Address (0x00004000 | kernel | kernel.img)
After that, my mk809 reboot in loop, and I don't see the Linuxium's bootloader.
Someone known where is the problem?
To be sure, the linux kernel partition is "kernel", not "recovery"?
Originally posted by GoblE View PostI have some trouble to use my own kernel (for Linux, not Android) :/
Originally posted by enrique66_35 View PostIt sounds like your kernel might be compiled to look for Linux/Android in a different location than you have prepared. For example kernel looks to NAND but files are on SD card. Check the CONFIG_CMDLINE= line in your config to make sure it's what it should be/matches Linuxium's config.
But it's strange, If the problem is directly linked to the kernel, why I don't see the Linuxium's bootloader menu (with startup loop) when I flash my custom kernel (into the "kernel" partition) ? :/
I have checked my CMDLINE variable into the parameters file, I don't see mistake :
Code:FIRMWARE_VER:4.1.1MACHINE_MODEL:rk31sdk MACHINE_ID:007 MANUFACTURER:RK30SDK MAGIC: 0x5041524B ATAG: 0x60000800 MACHINE: 3066 CHECK_MASK: 0x80 KERNEL_IMG: 0x60408000 #RECOVER_KEY: 1,1,0,20,0 CMDLINE:androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00008000@0x00004000(kernel),0x00008000@0x0000C000(boot),0x000C000@0x00014000(recovery),0x00100000@0x00020000(backup),0x00040000@0x00120000(cache),0x00400000@0x00160000(userdata),0x00002000@0x00560000(kpanic),0x00100000@0x00562000(system),0x00400000@0x00662000(user),-@0x00A62000(linux)
No, the boadloader (rockchip) is only able to boot from nand, so the kernel as img and the fitting/matching boot as img must be flashed to nand...
Do you flash the correct boot.img (initramfs) too?
If not, I think it could not work...
I don't know the linuxium menu (inside the boot.img(initramfs)????) but normally at your parameter there must be 'root=LABEL=linuxroot' to find the RFS...RK3288 Devices
- Overview BOX (LINK !)
Thanks again.
Maybe you have the same problem like me (MBR/MPT)...
#277 till #282RK3288 Devices
dual boot linux android
[QUOTE = linuxium; 157785] Si fa ora! Mi dispiace. [/ QUOTE]
Please linuxium, I have a problem with ubuntu account minix x7.
when I enter the terminal to write about sending change password
then password: "p" sending me and says Authentication failure please help me
thanks
RKM MK802 IV WiFi issue
Hello Ian, hello friends of Freaktab,
I've bought an Rikomagik MK802 IV (latest model - S/N 2014....) and I've installed dualboot succesfully: Both Android or Linux starts okey, and both Android and Linux detects and shows my wireless lan. The problem is in Linux when I'm trying to connect to the lan (typing root pwd and WiFi pwd), the network interface cannot conect properly, sending me a message window "the network is off". I've tested with the 3 linuxium distros (lubuntu, xubuntu and ubuntu 12.04) and all with the same results. In Android WiFi works perfect. Any missing module perhaps? Is sure my wifi chipset an AP1620?
Thanks a lot.
EDIT: I've tried today with linuxium-mali-ubuntu12.04.img and finally wifi works! The question now is that I cannot set spanish language (install languaje packs option disabled), and I just hate Unity. I will try update Ubuntu to 14.04 with sudo do-release-upgrade -d this afternoon for this issues.Last edited by gvigueras; 14 May 2014, 09:59.
Need Some Help
Hello,
This site looked promising so I joined and I hope I can get some direction/help on my endeavors. I have a Samsung Tablet (T217S) 7" recently and I am trying to figure out how I can remove the android and just run linux, any version of linux.
What I am trying to do is have the fastest booting OS, that goes into a graphical environment. Not really looking to get to command shell but that can be a first start.
I am working on a personal automotive project to replace gauges in my car with tablets and to use tablets in other applications to control other things in my car, like windows, etc. I can avoid having any exposed buttons or knobs. I will buy SBCs to handle the D2A, A2D signals but I want these tablets to have wireless capabilities to be able to talk to the SBC. Will be a closed network. Not thinking of blue tooth as I need the fast network possible.
So back to my tablet... I have rooted it and was playing around with removing apks from my ROM to see if I can get it as fast as possible, and hopefully not brick the device. Which I have done about 10 times so far! :-) The fastest I got it to boot up in Android is about 21 seconds. Not good. I want this unit to be up and running in less than 2 seconds. As a goal, faster is better.
So I would like to be able to fake out the bootloader on my device to start up a linux OS instead of Android or replace the boot loader altogether (and safely) so that I don't have to JTAG it.
Any suggestions and help appreciated.
Chris
There are currently 2076 users online. 1 members and 2075 guests.
