PMP5580 rom porting to NX008HD8G_WM
Originally posted by roadkill View Postcan i havd the link for the cm11 -ur trying out?
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostI got a chance to install your most recent CM11 port and everything seems to working acceptably (although this is the first time I've had the rotation artifacts appear). Even audio has an acceptable level for this tablet's tiny speaker.
Did you have anything specific I should test while I have it installed? Aside from the rotation issue, it seems to be working as well as the 10.1 version.
ShaunMTArchos Gen9 A80S cm-11.0
Kindle Fire 2 cm-11.0
Originally posted by stevemp View PostAmlogic has a 3.10 kernel with new mali kernel driver for the 8726MX that works with KitKat but I'm sure nextbook will never update, rather sell you a new tablet. From what I've read KitKat needs at least the 3.10 kernel for the performance boost to work. The only thing I really like about KitKat is the Google Now Launcher but it works on the stock rom if you install the Google libraries from a kitkat rom. All I did was make a few changes in the build.prop to get the screen and camera rotation corrected plus modified the boot.img to wipe system, data, and cache. The rest is CT's cm-11.0 build.Freaktab Rom Developer
Originally posted by shaunmt View PostThat reminds me... the camera isn't perfect... one of them is upside down... don't remember if it was the front or back camera...Archos Gen9 A80S cm-11.0
Originally posted by stevemp View PostSomeone reported that also but it's correct on my tablet. Did nextbook change the camera hw?Freaktab Rom Developer
Originally posted by skyhi View PostFinally got one of these custom roms to load and boot - cm10.1
I am now chasing sim toolkit error and no wifi - won't turn on.
Progress!
Code:on boot insmod /system/lib/narcpi.ko
I still don't have cm-11.0 working with the nextbook kernel, freezes before launcher starts.Archos Gen9 A80S cm-11.0
Originally posted by stevemp View PostFor the wifi to work copy /system/lib/narcpi.ko add a line in init.rc to load.
I think every Nextbook ROM I've seen has narcpi.ko, but I don't think any of them actually use it. It never even gets insmodded.
For example, my NX8000ND_WM has narcpi.ko, but it is not insmodded by init.rc and it is not listed under lsmod. My NX8000ND_WM uses dhd.ko for WiFi and I think the other NX8000NBD_WMN ROM I have uses something else.
Several other Nextbook ROMs also have narcpi.ko but use some other WiFi driver instead. I'm pretty sure it's just a leftover piece from some older tablet model.
Yeah I was already using the init.rc from my original tablet image and the narcpi.ko line is there and wifi doesn't work.
What I notice is I don't have a mac address now - any idea what configures this for this tablet?
Everything else seems to be working quite well!
Oh - got rid of sim toolkit by deleting stk.apk (also had an earlier error that I got rid of by deleting phone.apk)
Originally posted by skyhi View PostYeah I was already using the init.rc from my original tablet image and the narcpi.ko line is there and wifi doesn't work.
Oh - got rid of sim toolkit by deleting stk.apk (also had an earlier error that I got rid of by deleting phone.apk)Archos Gen9 A80S cm-11.0
Originally posted by shaunmt View PostReally?? If so, you definitely have a strange tablet.
ShaunMTI really haven't messed with the stock rom very much since the pmp5580c kernel works on my tablet.
There are currently 1953 users online. 1 members and 1952 guests.
