NX008HD8G Bricked
    There actually is no driver for the nextbook tabs. When you plug the in the detect as mass storage. If you unistall the driver you currently have inmolace you can get the right driver installed wich is the one for an Amlogic M3 nit M6. You may have installed tthe M6 driver by accident as it often is packaged with the M3 one.
      Well I decided since nothing was working anyways I'd give cm11 a try (PMP5580 rom porting to NX008HD8G_WM). Everything seemed to work fine until once again I rebooted the device & there was that mtd5 error again...
      This is getting aggravating, if stuff is just going to keep throwing file system errors at me then I think I should listen & just stop trying, I think the device just gave up.
      Nextbook NX008HD8G - Rooted
        q
        Originally posted by silver9990 View Post
        Well I decided since nothing was working anyways I'd give cm11 a try (PMP5580 rom porting to NX008HD8G_WM). Everything seemed to work fine until once again I rebooted the device & there was that md5 error again...
        that's strange working good for me I going to search for that error this is to strange
          Well, I can't even get this thing to boot into recovery off of the sd card anymore so I'm thinking it's fried.
            q
            u by chance arnt conceted to pc whille trying to boot pull sd card out an put it on pc and format it or check it to see if it bad it happens
              Plugged into the wall. I just checked the card & it's fine. I was doing another recovery earlier but it shut off while it was flashing a file & now it's not coming back on, I'm wondering if the sd slot didn't just go bad.
                q
                not good when shuts of while flashing i geuse it could b posibale the slot bad ?
                  Can happen... I had an HTC Evo Shift with a SD Card slot that died... at prices of these tablets, you can be sure they aren't using the highest quality parts...
                  Freaktab Rom Developer
                    Would it be possible to use AML Tools to load the rom recovery archive or does that require the archive to have specific files?
                      The AML tools require special files that tell the software how to partition and format the nand and how to install the ROM. We don't have the required files and we don't know how to create them either.
                      Without out the correct files, the AML tools can only be used to completely erase the nand.
                        Well, is there anything else I can do for this thing or should I just give up on it?
                          q
                          dont give up try googling the problem ur having and go to xda site at this point u have nothing to loose just for the fun of it try to get into cwm with volume upmand power if dont work try volume down thats what i have to do some times
                            Tried to search for that error but didn't come up with anything. I'll head over there & see what they say I guess.
                              q
                              cool
                                q
                                from what i was reading u need to get adb set up amd need to push comands to ur nan amd thing i was in xda site the mtd5 or others nan parts need to b errased or somthing little over my head at least ther is some hope
