NX008HD8G Bricked
    link
    fuser-invent has a thread on slatedroid on how to unbrick amlogic tablets, worked for me when I hard bricked mine. http://www.slatedroid.com/topic/4147...es-tablet-v20/
    ​Archos Gen9 A80S cm-11.0
    Kindle Fire 2 cm-11.0
      Thanks for all the help but I'm done trying with this thing, the owner dropped it before it bricked so I'm thinking the screen just finally decided to go (it's cracked in more than one place).
      Nextbook NX008HD8G - Rooted
        It seems the screen wasn't screwed after all, it seems it just didn't want to boot into recovery using an 8 gb sd card. Either way I'm still done with it, no matter what I try I keep getting that cannot attach mtd5 error.
        Thanks again for all your help, the people here seem to know a great deal & I've learned quite a bit in my time here so far.
          mtd5 is the system partition... if you can get to recovery, it should be possible to reformat the system partition and flash a ROM...
          All of my ROMs reformat the system before flashing anyhow...
          ShaunMT
          Freaktab Rom Developer
            Ok, I've been able to verify that this thing is toast (same device as the one in the rom porting thread).
            I dumped the log after redoing everything from factory reset to installing the new rom & there are tons of errors in there:
            Code:
            -- Wiping data...
            Formatting /data...
            Formatting /cache...
            mtd: not erasing bad block at 0x00000000
            mtd: not erasing bad block at 0x00200000
            Formatting /sd-ext...
            I:Formatting unknown device.
            No app2sd partition found. Skipping format of /sd-ext.
            Formatting /emmc/.android_secure...
            W:failed to mount /dev/block/avnftli1 (No such file or directory)
            Error mounting /emmc/.android_secure!
            Skipping format...
            Data wipe complete.
            Code:
            Formatting /system...
            mtd: not erasing bad block at 0x08400000
            mtd: not erasing bad block at 0x08600000
            Done.
            Code:
            -- Installing: /sdcard/Next8HD8G_SMT_Stock_Rom_070113-signed.zip
            Finding update package...
            I:Update location: /sdcard/Next8HD8G_SMT_Stock_Rom_070113-signed.zip
            Opening update package...
            Installing update...
            mtd: not erasing bad block at 0x00800000
            etc...
            So yea, it's just not going to happen.
            I wish I'd have known about that log sooner, it would've saved me a whole lot of trouble & headaches.
              Code:
              -- Wiping data...
              Formatting /data...
              Skipping format...
              Data wipe complete.
              Code:
              Done.
              Code:
              etc...
              Yeah... those bad blocks are the problem... the only way to fix that would be a low level format that mapped the bad blocks so they get skipped...
              unfortunately, I don't think we have the tools available to do that...
              ShaunMT
