NEW - Tronsmart A928 KitKat 4.4.2 Finless 2.0 ROM
    This rom fix Frameskipping videos streaming?
    Enviado desde mi MI 3W mediante Tapatalk
      It has the patch in it for that.
        hey Bob,
        With the OC kernel, is both GPU and CPU overclocked Or only the CPU?
        Also, other roms has tons of overclocked kernel options. Are you cooking several kernel options for this tv box too?
        Thanks!
          Originally posted by peekeesh View Post
          hey Bob,
          Thanks!
          All A928 boxes are 3188-T chips. The OC kernel overclocks CPU to 1.6 (like non-T chip) and DDR to 677. My README explains what the OC Kernels are.
          We have not unlocked GPU fully yet. But let me just say GPU overclock really never adds much to performance so I would not worry about it. If D33 gets more help with mali and OC (I plan to help testing just have not had time), we may get OC GPU better.
            mk908ii no audio
            Finless, while everything in your rom works fantastic I appear to get no audio when paired with d33's v2.0 SD kernel. What do I need to do to modify this rom to work with the mk908ii's audio chipset?
            This appears to be a kernel issue, as such I'll address it on d33's thread. Audio started working after I flashed stock kernel from mk908ii kitkat build.
            Only after you've donated to Finless and Neomode are you allowed to donate here.
              RK Remote Control
              Hi Bob,
              One more question: I see that not working yet RK Remote Control.......this remote is IR remote included in the package no?
              Thanks!!
                Re: NEW - Tronsmart A928 KitKat 4.4.2 Finless 2.0 ROM
                Hi Bob,
                Thanks!!
                The included remote is RF with microphone and audio out (headphone jack) however I am impressed with the built in IR.
                Sent from my Nexus 4 using Tapatalk
                  No, the original remote in a928 (all brands) is IR, the Remote control with microphone and audio out is a extra for tronsmart brand. I want to know if the fly mouse works with this rom. I no use the IR remote
                    No, the original remote in a928 (all brands) is IR, the Remote control with microphone and audio out is a extra for tronsmart brand. I want to know if the fly mouse works with this ROM. I no use the IR remote
                    Uh.. This is the tronsmart forum. The rk remote (network) doesn't work in kitkat yet. The flymouse does in fact work. I haven't tested the audio functions yet.
                        Thanks!! one more! What kernel you choose??
                          d33's new 2.07 kernel for AP6330 patched for OC with rkpatchomatic.
                          kernel_t_AP6330_HD_v207_cpu1608h_gpu798h_ddr800 gives me 17370 at 1080p 60hz in antutu. (note I disabled many builtin unnecessary services such as email as I only use my units for Chrome and XBMC so your results may vary as always.)
                          EDIT: Made the kernel above a shared link from google drive. Enjoy!
                            I'm using the 1080 kernel with the 1080 boot and I can't play any 1080 video (very choppy).
                            Can anyone test this video to see if its ok? http://www.techpowerup.com/downloads...us-5-1/mirrors
                            Thanks,
                              Has anybody noticed the included remote having its back button sticking and repeating until another key on the remote (2.4ghz not IR) is pressed? Mine sticks on two separate 2.4ghz remotes its most frequent in XBMC (Frodo or Gotham)
                              Sent from my mobile device. Please excuse any typos.
                                Just got A928 from geekbuying and downloaded the firmware.
                                However, I am not able to let XP detect the system after plugin the USB OTG.
                                Which USB should I connect to?
