Battery Life
Originally posted by dwilkins View PostI'd be interested in that link as well.
-- dwilkins
On the 7s, the case is snap-fit, so there could be issues with getting it apart and back together successfully.
I decided not to bother, and returned mine for a 702c - sans OEM-included pictures, of course...
73 DE N4RPS
Rob
Mine opened easily
Originally posted by Mr.Chips View PostJust picked up NextBook Premium 7S and like many have said the battery life if pretty bad.
I am interested in a battery swap, or could you add an external battery to increase life?
What are the tricks on opening it up to take a look around?
HH
I was successful with a thin piece of plastic. The perfect tool is one of those plastic pry-bars that's used to lift the glass off of a smartphone.
As mentioned in an earlier post, start prying on the corner / side opposite the power button. I was able to "get my foot in the door" easiest around the power/USB area.
I did accidentally damage a couple of the "hooks" that hold it together. they didn't break and I just re-positioned them and added a little super-glue to shore them up. Once the super-glue dried I snapped it back together easily. I took a couple of pictures of the inside and I'll try to post them later.
The battery was secured with copious amounts of very strong adhesive. I think that I could coax it loose, but I didn't try since this was "bought for my wife" (I've ordered her a Nexus 7, so the 7s is going to donate it's body to science in a couple of weeks).
Originally posted by dwilkins View PostI opened mine, trying to be very careful and not use anything that might damage the seam and make it look like a gorilla had tried to open it.
HH
There are currently 1592 users online. 0 members and 1592 guests.
