Custom kernel for M6Pro
    Re: Custom kernel for M6Pro
    Originally posted by giouncino View Post
    It has 1.35V for 1704Mhz, it's still a little bit high.
    I'm preparing some patched variation. I will upload them very soon!
    In any case: many thanks Maakie! You're doing a very good job!
    CPU tweaker shows only 1.25 V at 1704 MHz.
    Kernel running very stable for nearly a week on my tablet
    Sent from Tapatalk on my m6pro running Riley ROM 1.8 KK
      this is the voltage table for the CPU:
      == Table 6 at offset 9322292 ==
      MHz mV
      312 900
      504 925
      816 1000
      1008 1075
      1200 1200
      1416 1250
      1608 1300
      1704 1350
      I think that CPU twaeker is wrong....
        here is a link:
        百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
        which red border are you talking about?
        Can I test it too? Password please
          Originally posted by maakie View Post
          Here is a new version with some stability fixes.
          very good and stable. antutu goes 20887
            I have compiled a new version of the kernel for M6Pro with the following new features:
            * Added color and sound control (use for example the app Trickster MOD to change settings)
            * Added some schedulers and governors & fixed a bug in hotplug governor
            * Deep sleep works with the stock libril-rk29-dataonly.so for possibly better 3G reception
            * Changed some frequencies
            * ...and some other minor changes
            Unfortunately it seems I can not attach it to my post, so you'll have to wait a little.
              extremely interesting!
              I'll wait for this new kernel!
                I will try. is it possible to increase the battery life?still just 4 or 5hours. but the cpu is not lucky one. just your kernel stable.
                  You can now download it here.
                    thanks!
                    I will test it immediately!
                      Seems to work very nicely, thanks Maakie. The 216 MHz freq should help improve battery life
                        Are you sure?
                        I think that 216Mhz is too low to be used by the tablet, and in any case has a voltage higher than 312Mhz in some modded kernels.
                        I've removed it on my modded versions.
                        It's a very good kernel though!
                        Very good job maakie
                          I installed this kernel. very good so far. 216mhz save battery life. I have unlucky cpu.could not use low votage mod kernel,but this one gives me that and very stable. thanks
                            I think you cannot say that NOW. You need to use the tablet for a while with this kernel and see how much time your tablet stay at 216Mhz in normal use and see if REALLY 216 save battery is such a way that could be visible!
                              That's true but it's looking very promising, the CPU spends a lot of time at 216 when the tablet is idling or your app is not doing much.
                                I tested this kernel this morning, and after 3 minutes the tablet restarted.
                                So I went back to the old version of M6Pro_140418.
                                Is it my tablet that is truly "bad luck"?
                                : Mad:
                                What I've always 3G signal that cuts alone even with the PIPO 4.2.2 ROM
                                Thank you anyway for your work.
