Custom kernel for M6Pro
Originally posted by min0taur View PostThanks for this cool kernel! But I encounter a battery problem when charging from off.if you appreciate my efforts this is the link for any donation:
Re: Custom kernel for M6Pro
Been using M6Pro_140427_r5 for a couple of days and haven't had any issues with it. My M6Pro is the most responsive and stable it has ever been. Many thanks for the efforts of maakie and all others involved in making this kernel.
I have an unlucky CPU. In spite of that I think I will try some of giouncino's tweaked versions of this kernel to see how they work on my tablet. Fingers crossed.
Sent from my Galaxy Nexus using Tapatalk
Originally posted by min0taur View PostI fully charged the device while turned off but after i turned it on the battery level is only 5%Last edited by giouncino; 01 May 2014, 22:06.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostIt's very strange!That was a problem of the first maakie's version!At the moment, also my tablet is charging from off. I will give you some feedback soon!------------------------------------------UPDATE------------------------------------------Charging from off condition is perfectly working.I'm using a modded version of the latest maakie kernel, but I think it's not significant
1. Fully charged device off
2. Turned on 91% and after a minute goes to 87%
3. Flashed stock kernel (The one included in ROM Package) battery 56%
4. Flashed back to latest OC kernel battery: 87%
5. Flashed stock kernel from chinese kitkat ROM battery: 56%
Don't know if its a hardware issue or what
Originally posted by min0taur View PostSeems a problem with my program or something reflashed the whole rom fixed the issueif you appreciate my efforts this is the link for any donation:
Originally posted by min0taur View PostNow using stock kernel... Hopefully you will take a look at the battery charging problemif you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostDid you try my modded one based on the kernel prepared by maakie? Many people are using these kernels and no one have your problem.
I decided to wipe my M6Pro and start with a clean Reilly 1.8 install, adding back apps slowly. I installed the latest maakie kernel and found it to be very stable and quite responsive/smooth. I only added back a dozen or so of the apps I use regularly. Everything was incredibly stable. No issues whatsoever.
I decided to try my luck with your cpu/mem overclocked versions of the latest maakie. I am now running the 1704/1.325 with 768 ram and it has been rock solid. It appears that my CPU is NOT unlucky. Either my OS got flaky somewhere along the way with my kernel flashing, or the maakie kernel is more stable or I had a rogue app causing issues. It could also have been the launcher. I am currently using Google Now launcher whereas I wasn't before.
The short of it... Perhaps going back to step one and building from there might yield better results for users. It was definitely worth the effort for me. This tablet now rocks! Thanks maakie and giouncino.
There are currently 4360 users online. 0 members and 4360 guests.
