Custom kernel for M6Pro
Originally posted by maakie View Postif you appreciate my efforts this is the link for any donation:
Originally posted by maakie View PostI don't have Miracast device which makes this problem hard to fix for now.
Just to see if there is something useful to be used into m6pro kitkat future kernel...if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostCould you please take a look on m8pro kitkat kernel about miracast? because that kernel is working properly with X5 dongle.
Could this be only a library problem (but which ) ?
I have tried on my M8pro and it works
not on M8HD (old release 02/2014)
STOCK Kernel: 34 seconds
Your Kernel: 1 minute and 12 seconds
Do you know why with your kernel is it so slow on booting?if you appreciate my efforts this is the link for any donation:
Re: Custom kernel for M6Pro
Originally posted by giouncino View PostAfter a fresh install of the whole kitkat ROM I tested the boot time with stock and your kernel:
Tapatalk-kal küldve az én M6Pro-el
Originally posted by karmantyu View PostAnd the stock kernel discharging the device about 3% a day while the custom one eats about 10% of the juice.
How can you say that?if you appreciate my efforts this is the link for any donation:
I flashed back the stock kernel because I remembered that it has much better standby times than the custom ones. As far as I remember I made a statement about this some times ago already. So test it yourself if you are not believing me master.
Originally posted by karmantyu View PostIt's quite easy to measure. Flashback the stock kernel - with modified clocks by you - and leave your tab on standby. Sometimes you can check battery log for making sure yourself. Here am I typing, the tablet's battery is on standby since two days, charge level is 92%.
It's not a matter of believing!!!!if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostI asked you that only to undestand if it was a problem of stanby discharge or a general faster discharge problem!
Originally posted by karmantyu View PostOK. I might not described it well. It is clearly a faster standby discharge problem which causes general faster discharge too.if you appreciate my efforts this is the link for any donation:
Originally posted by claro966 View PostWhich kernel is better for 3g on RR 1.8.1?
The most important thing is to use the libril file I posted here! (that is the kitkat stock libril)if you appreciate my efforts this is the link for any donation:
R: Custom kernel for M6Pro
Finally I solved my 3G issue.... It was the sim card blocked
BTW where did you exactly post the link?
I can't find it.....
Thank you so much
Thank you so much
post #749if you appreciate my efforts this is the link for any donation:
There are currently 1563 users online. 0 members and 1563 guests.
