Arnova 7 G3 is ROOTED out of the Box!!!!!
Not sure regard undervolting ing etc..
Play market..follow bobs post..
Setcpu and OCing works great take a look at my guides on arctablet.com... for more on market,setcpu etc...
Battery.., am getting 4-6 hours out of mine and thats with 271 apps installed and using wifi sceen almost alwas full brightness..but 6 hours is verynlittle wifi and low brightness..
My tablets OCed..
have now used a usb keyboard and mouse(adpters are 98p on ****) and works well..
My tablets OCed..
sent from my Arnova 10 G2
I am sure that getting google to say compatible is a simple build.prop file edit and telling it you are some other device! Especially if facebook app side loads OK.
See if you can find a ICS tablet build.prop that is compatiable and swap it. If your rooted this is easy.
Originally posted by Finless View PostI am sure that getting google to say compatible is a simple build.prop file edit and telling it you are some other device! Especially if facebook app side loads OK.
Originally posted by Finless View PostI am sure that getting google to say compatible is a simple build.prop file edit and telling it you are some other device! Especially if facebook app side loads OK. See if you can find a ICS tablet build.prop that is compatiable and swap it. If your rooted this is easy. Bob
Originally posted by lohtse View PostHi apologies for late reply have had a busy duty period due to the weather etc.. anyway the facebook thing works as you have found by sideloading but also try searching and adding the files I mentioned earlier in the thread too.. As to the red light yep thas how it should be and will change colour or flash(can't remember which) when batter is low...
cheers
update i found the 2 files for him..hes done it..able to install google currents now from play but no maps still...any ideas? no social stuff twitter etc is compatable at all..so looks like a lot of side loading for him to do i guess?Last edited by gadgetuk; 12 June 2012, 12:00.
Originally posted by gadgetuk View Posthave you got these files to share as i dont want to send him the incorrect ones..so if u can zip them up for me that be great cheers update i found the 2 files for him..hes done it..able to install google currents now from play but no maps still...any ideas? no social stuff twitter etc is compatable at all..so looks like a lot of side loading for him to do i guess?
There are currently 3008 users online. 0 members and 3008 guests.
