Verstuurd van mijn Galaxy Gio GT-S5660 met Tapatalk
Arnova 7 G3 is ROOTED out of the Box!!!!!
and with the same apk?
Verstuurd van mijn Galaxy Gio GT-S5660 met Tapatalkif you love my work please buy a coffee
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
</form>
Originally posted by lohtse View Postyep....... for some reason the 7G3 doesn't play nice
Cheers bob...
I know somewhere theres a fix to sort out app compatability when they show work without issues (had to copy two files to sysem) and just can't remember where and what they are...any one have any ideas?
found it...Turns out that pasting com.google.android.maps.xml and com.google.android.maps.jar into /system/etc/permissions and /system/framework/ respectively was part of the answer, but permissions need to be set to Owner/Read, Owner/Write, Group/Read, and Others/Read.
Reboot and both apps will install just fine.
Originally posted by cc6r2006 View Posthelp!!! i had used root explorer to put the apks in system/app , and i reset and format the device and stuck in setup wizard , its keep stopped and cant click back to home screen or other apps, only able to access to system setting...........totally shit now........
Aldo install adb drives(arctablet.com 7g3 as modded by me) then install androidcommander(google it) this will see system/app folder Delete apks you added and restart....
Originally posted by lohtse View PostHave you searched for a way to do full device reset? Havent needed to myself! Email Arnova too..... Am not sure why your device has done what its done...
thank you so much!!! i fixed now loolLast edited by cc6r2006; 09 June 2012, 02:34.
Originally posted by lohtse View PostHad this lovely tablet less than three days and messed with it alot....
during this messing around I installed a few apps that allow more functions when rooted... And to my delight I had these functions without notifications.... One or two apps complained about busybox so I updated busybox and hey presto they WORKED!!! Tried superuser but didn't so I updated binaries and now you get full notifications etc...
This dang nice tablet was fully rooted from the moment it left the factory!!!!!!
regards
Lohtse
Can you comment on battery life...cheers
Alan
sent from my Arnova 10 G2
Originally posted by gadgetuk View PostWhere you purchase from? As seen in currys...for 109.99 arnova 7d g3 guess this is the same..?
Alan
And was bought in currys...
Battery last 4-6 hours depending on screen,wifi etc... not sure on stand by time as not left it long enough to find out..
There are currently 2237 users online. 0 members and 2237 guests.
