Arnova 7 G3 is ROOTED out of the Box!!!!!
Originally posted by cc6r2006 View Postthe one you looked on their website is 7d g3, but if u in the store will shown diff one which is 7 g3, i asked their staff even they dont know why loool
Originally posted by lohtse View PostIt is 7g3 NOT 7d g3....totally dif tabs...and uk version of 7 g3 only has 4gig internal..
But thanks for all the info
Originally posted by gadgetuk View PostNevermind he's not going to get this he's getting a 99.99 one from currys with android 4 and google play already on it called a versus 7" touchpad ( apparently this was on offer last week for 79.99 ) but to late now .. It's got similar battery life of around 4 hrs .. Was going to invest in a iPad 2 like mine but he's needs another car lol so 100 is is limit)
Originally posted by lohtse View PostLooked at that and a few reviews and decided against it as seems more like a very cheap chinese knock off and as yet no one ,managed to root it..also when we played with it in currys it had a very dark screen,view angles are bad, only two point touch and camera was bad... but hey it is cheap..
Yeah, looked at the Versus and think you'd be better off paying another tenner for the Arnova!
The GoTab looks like it's made by Yarvik but it might just be the same name! Difficult to tell from the Ideal World site.
<edit> - It's not a Yarvik, Ideal World sends you to http://www.ergoelectronics.com/
Looks to be a small company so will probably be re-badging Chinese tablets.
Originally posted by MrWeelson View PostYeah, looked at the Versus and think you'd be better off paying another tenner for the Arnova!
Yes, the 7G3 from Curry's/PC World is rooted out of the box, I bought mine from there last weekend and I'm happily running Titanium Backup with Superuser & SetCPU.
IMHO the 7G3 is much better than the Versus, I wasn't at all impressed with the screen on the Versus, viewing angles were poor and the screen felt sticky, not nice to use at all. Battery life is around 4hrs on the 7G3 and it seems to loose about 1% or less of battery capacity in 8hrs of standby which I consider to be pretty good after my Hannspad!
Originally posted by SRH990 View PostYes, the 7G3 from Curry's/PC World is rooted out of the box, I bought mine from there last weekend and I'm happily running Titanium Backup with Superuser & SetCPU.
One more thing he asked.. How goods the app support for it on google play?
And with setcpu did you get and more out the proccessor
Update which method in the end makes google play etc work as bit confused with diff posts I see in here..as will help my m8 with this
CheersLast edited by gadgetuk; 10 June 2012, 18:38.
There are currently 3773 users online. 0 members and 3773 guests.
