[Product Review] Tronsmart Vega S89 HDMI and Optical Passthrough Test
Re: [Product Review] Tronsmart Vega S89 HDMI and Optical Passthrough Test
Originally posted by tikboy View Postjust receive my Tronsmart vega s89 yesterday ordered from geekbuying, excited to use it to replace my old MK808, to my surprise some the add-ons for xbmc is incompatible and then the antutu bencmark results is only 23468. i will attached some picture
I've downloaded Trickster mod and used the frequency lock to change the max to 1.99 and minimum to 1.4ghz and the box absolutely flys (although you can't antutu using the trickster frequency it seems to mess it up).
It seems the kernel was made for a tablet and needs work done on it (hopefully the sources are fully open and this is possible). The ROM also needs work done on it as you can't download paid apps without getting an error.
I would also guess the XBMC problem is because XBMC is in beta testing.
Sent from my Nexus 5 using Tapatalk
HI
thanks for all of the problem feedback, i have written down all of the problems, and prepare to talk with factory, and push them to fix.
EricLooking for developers
Eric
Sent from my Nexus 7 using Tapatalk
Originally posted by Batfink32 View PostI've downloaded Trickster mod and used the frequency lock to change the max to 1.99 and minimum to 1.4ghz and the box absolutely flys (although you can't antutu using the trickster frequency it seems to mess it up).
I really don't care about Antutu or other benchmark scores. Smoothness and lag free is very important to me.~Gopichand Pai
Originally posted by gopichandpai View PostYou mentioned in the other thread that it doesn't stay on higher frequency for long. With Trickster, does it stay on 1.99? Does it get heated up?
I didn't feel much heat from it at all set to min and max 1.99Ghz and the box felt cool.
To be honest the kernel is a mess and is really stopping the full potential if the box. I think I said if the kernel can be optimized the box will be very, very fast it has the potential.
Originally posted by kotobide View PostEric can you confirm that the Vega s89's your selling have the s802 or s802d or s802h?
Originally posted by kotobide View PostMy only worry with the software handling it is having sync issues have you recieved your vega yet?
Originally posted by Batfink32 View PostI've tested a few videos and there is big sync issues on XBMC.
Originally posted by kotobide View PostSync issues would really keep me from pulling the trigger and buying this device. I guess ill just keep waiting to see if any of this gets sorted by custom roms or if its something that can get fixed by customizing the kernal.
I thought the sync issues could be solved with the usual advanced settings xml
You can select hardware and software decoding in MX player, if the hardware doesn't support the codec then you get no sound. Flip to software audio decoder and see if it works.
Sent from my mobile device. Please excuse any typos.
Originally posted by noderat View PostYou can select hardware and software decoding in MX player, if the hardware doesn't support the codec then you get no sound. Flip to software audio decoder and see if it works.
Also use the latest nightly with xbmc but when posting results make sure to post the build date/git info from system info
There are currently 3500 users online. 1 members and 3499 guests.
