[Product Review] Tronsmart Vega S89 HDMI and Optical Passthrough Test
Okay, found it : https://play.google.com/store/apps/d...emoteIME&hl=fr
but not an update since 1 year...
Originally posted by Millenius View PostOkay, found it : https://play.google.com/store/apps/d...emoteIME&hl=fr
Originally posted by Millenius View PostI tried the RemoteIME app... but it's very very very not responsive :/
There is a big lag between the touch, and the response.
Is there any other efficient solution ?
Has Someone tried a real keyboard (like Logitech K400) ?
It could be wifi related?
Just plug the dongle into USB port and check
Originally posted by Millenius View PostWhen I said very lag, it's ~300/500ms
and the keyboard is not working very well...
I will do more tests in few hours
No thats way too bad... I us galaxy S4 phone. Maybe its your phone that relay the commands to slow?
Mine is instant - no delay.
I used a Logitec LX 710 wireless keyboard & mouse - also perfect with no delay
Originally posted by Millenius View PostHi,
Any update about the 0.5ms audio unsync issue ?
Thx in advance
Or try this:
Audio out of sync
- You need to make the file 'advancedsettings.xml' and save it to folder
Android/data/data/org.xbmc.xbmc/files/.xbmc/userdata/
- As far as what value to put in for the delay, I used the audio offset option in xbmc to determine where I needed it to be. When playing a movie, select the speaker icon on the lower right portion of the screen, adjust audio offset, and drag the slider bar to where the audio/video sync. Use that value for your latency setting.
- yours was 250 out, mine is 350, but I started with 250 and moved upRK3288 Devices
- Overview BOX (LINK !)
There are currently 3380 users online. 2 members and 3378 guests.
